Kia sportage rear end into SE?
Old Jul 1, 2003 | 11:53 PM
O 16581 72452 5's Avatar
The infamous number guy!
I did a search on this topic because i know it's been discussed before, but i couldn't come up with much, supposedly this rear end will fit into a miata, and a miata rear end will fit into an FB. So the sportage rear end should fit into an FB, does anyone know for a fact that it will? any information given about this will be greatly appreciated. thanks in advance.
Old Jul 2, 2003 | 12:24 AM
rx7gslse's Avatar
EX Pres of DFW Drunks
"some" miata pumpkins can be swapped with "some" Rx7 pumpikns...
and "some" Kia sportage diffs are swappable with "some" miata diffs, along with "some" mazda truck diffs...
it's a bit more complicated than you think...
start reading this 1st.
http://members.aol.com/solomiata/MiataCSP.html
Old Jul 2, 2003 | 12:27 AM
The WHOLE rear end isn't swapable? just the pumpkin in some cases?
Old Jul 2, 2003 | 08:59 AM
rx7gslse's Avatar
what are you defining as the "whole" rearend?
Old Jul 2, 2003 | 09:19 AM
nosajwrx-7's Avatar
Rotax, Rotaries & Turbos
The whole rearend consists of housing, pumpkin, and axels.
From what I understood from the website, may of the switches are ring and pinion gears only into you current unit, or one that you will be installing.
Also, as a side note. ring and pinion gears are made in sets and are ground to work as a set. You should not swap one without the matching other.
Old Jul 2, 2003 | 11:15 AM
MikeLMR's Avatar
'Last Minute' Rallying
If I recall correctly it is only the Crownwheel and pinion from the Kia diff that is swapped over to get the lower geared rear end. (and no one has tired it and reported back yet)
Mike
Old Jul 2, 2003 | 11:22 AM
rx7gslse's Avatar
that's what I though, I just wanted to be sure we were on the same page...
and from my understanding some miata pumpkins are swappable, but there is a couple mm fewer of spline engagement (and only on 84 up?)
As for the Kia & mazda pickup difs, I'm was under the enderstanding it was just the ring & pinion that you could use to get a lower ratio...
something about some the 4wd B2200's have 5.12 fronts? or was it 4.88... Hel a year ago I knew all of this stuff
Old Jul 3, 2003 | 12:06 PM
Maguire's Avatar
Born 2 Brap
If i remember right, people were getting 4.88 off the FRONT of the kia's, and pickups. not the rear. and of course only on the 4wd models.
Old Jul 3, 2003 | 01:15 PM
rx7gslse's Avatar
yeah... front.
Old Jul 3, 2003 | 09:27 PM
excitingleopard's Avatar
Prosthetic head.
WHY?
Seriously... it's a freaking Kia.
Old Jul 3, 2003 | 09:40 PM
Rx7carl's Avatar
Airflow is my life
Heh, have you priced a set of gears?
Th0m4s
Feb 26, 2019 02:04 AM
coltboostin
Rotary Drag Racing
Aug 20, 2015 11:37 PM
