misfire above 4000rpms
Old Jul 1, 2003 | 11:25 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
Unhappy misfire above 4000rpms
Washed the engine compartment now the 12a J-Bridge is misfiring above 4000rpms. Timing light says the engine fires above 4000rpms but the timing is way off, as in the timing light will light up but none of the marks on the front pulley can be seen.
Idles great, timing fine above 4000rpms.
MSD direct fire. Replaced MSD box and 1 coil already, didn't fix.
Put in another set of plug wires, didn't fix.
Went back to STOCK ignition using ignitor and no MSD box, didn't fix.
Routed power, pickup, and coil wires for MSD away from each other, didn't fix.
Removed and cleaned out carb, put it back on tight with no leaks, didn't fix.
Any ideas? Think the alternator or other electronic device is shorting and interfering with ignition system?
Thanks,
Old Jul 1, 2003 | 11:38 AM
RacerX7fb's Avatar
paradox
Moisture under the distributor cap?
Old Jul 1, 2003 | 01:13 PM
DriveFast7's Avatar
new cap and rotor
cleaned out the glass fuel filter before the carb.
stumped. HELP!?!?!?!?!
Old Jul 1, 2003 | 01:19 PM
enigma32's Avatar
Just a stab in the dark since I know nothing about timing, but is it possible that the belt is slipping?
Old Jul 1, 2003 | 02:53 PM
Turbo Driver
There is no belt.
Old Jul 1, 2003 | 02:58 PM
enigma32's Avatar
So then what "marks on the front pulley" are being looked for?
Old Jul 1, 2003 | 03:09 PM
Turbo Driver
There's timing, it's just not belt controlled....the marks are timing marks.
Old Jul 1, 2003 | 03:22 PM
enigma32's Avatar
hmmm
Well, I didn't say that I thought a slipping belt would affect the timing =)
I meant that the belt could be slipping and thus the marks wouldn't show up in the right place?
(i.e., perhaps it's not necessarily a timing issue?)
But, like I said, I know nothing about timing
So I'll just watch the thread and learn, hehe
Old Jul 1, 2003 | 04:25 PM
DriveFast7's Avatar
also installed 2 other distributors and same thing . . .
Old Jul 1, 2003 | 05:08 PM
driftaholic's Avatar
John Deere Drifter
From: "Drifting has a rice filter, its called Skill."
I have the same problem with my streetported 12a, the only conclution I can come to is the mixture is becoming to rich or lean at high RPMs. fuel delivery problem? I believe my problem is a overy rich mixture at high RPMs due to inseficient carberator flow capacity.
let me know what you find... maybee it will help me too
Old Jul 12, 2003 | 04:35 PM
bliffle's Avatar
I have a miss above 4k that is cured by a stroke of the accelerator pump, so I figure it's a carb problem.
But if the timing mark doesn't show at 4k it must be a slipping distributor, and I can't figure that.
B
Old Jul 12, 2003 | 09:20 PM
Replace your plugs regaurdless of how they look and it should fix the prob.
alphawolff
Nov 17, 2015 05:57 PM
befarrer
Sep 22, 2015 09:33 AM
R7rexy
19
Sep 2, 2015 10:24 AM
rxmiles
Aug 24, 2015 02:07 PM
