swapping dual to single ditributor?
Old Jun 30, 2003 | 10:35 PM
gradedcheese's Avatar
out of curiosity how hard would it be to install the later single-distributor breakerless ignition stuff on my stock dual-distributor 12A in the RX-2?
It looks like the motor's front cover is going to have tto be off, is this something you take the motor out of the car to do?
Old Jul 1, 2003 | 06:58 PM
Re-Speed.com's Avatar
I think you would have a hard time doing it in the car. The engine realy needs to be laying on its back when you remove the front pully and cover. It is an easy swap though.
-billy
Old Jul 1, 2003 | 11:12 PM
rxtasy3's Avatar
I did one without pulling the engine out. U'll have to drain the oil and remove the oil pan, or at least drop it down in front to get the front cover off.
Old Jul 2, 2003 | 01:57 AM
Jeff20B's Avatar
Lapping = Fapping
Any '74 or later front cover can be used. You'll need to tap threads into one of the bolt holes in the front cover and use a larger bolt as a plug. Or atleast that's what I did. I used a 10 x 1.25 or 1.5 tap (both are common Mazda thread pitches). Also, one of the front cover bolt holes on the engine under the water pump mounting area won't be used. It can be filled with silicone to prevent oil from leaking upward as it gets sprayed off of the counterweight.
That ought to be enough info to get you started.
Old Jul 2, 2003 | 11:50 AM
What do you do about the thrust bearing on the front of the e shaft? Is there a way to hold it in place to put the pulley back on - without it dropping and getting crushed?
-billy
Old Jul 2, 2003 | 01:05 PM
wow, thanks for the info, sounds very doable but I think I'll pull the motor to do it so for now I'll gather the parts for this and the gearbox and exhaust and then pull it and do it all at once I think.
Skeese
65
Mar 28, 2017 03:30 PM
ChrisRX8PR
Oct 18, 2015 04:01 PM
