Complete Automatic to Manual Conversion Write UP
Old Jun 29, 2003 | 11:38 PM
V8kilr's Avatar
This is a complete writeup on how to swap your automatic out for a manual transmission. This is mainly based on an 89-91 RX7, 86-87 similar.
Ok I Have done this swap from start to finish, so I will walk you through it step by step and show you short cuts when ever possible.
Dont be a fool and go by the other write ups out there, this write up will shave hours off your install, and make sure the job is done proper.
Step 1: Automatic Shifter Removal
To remove the automatic shifter you first remove the two phillips screws on the front of the shifter unit, then pull up the shift lever, below it you will find four 10mm bolts holding the shifter assembly in place.
Remove the three easy bolts, one will be tough, to get it out remove the power mirror switch panel.
Remove the two 10mm bolts under it, now you can simple pry the whole console over enough to remove the last bolt and pull out the assembly.
Dont forget you still have to disconnect the two wire harness's and the shifter linkge, pull up on the unit and you will be able to unclip the shifter linkage.
Now you will need to remove the nuetral lockout plunger, maybe its called something else? Its the thing that looks like a brake cable and goes up under neath the center console. You will need to locate the same piece under your steering column, there you will disconnect it as well.
Step 2: Instrument Cluster Swap Out
Ok there are a couple reasons to switch your instrument cluster, 1 being your current tach max is 7k, The current max tach on a manual is 8k, also lets not forget about the little lights that say PRND21 and HOLD.
Simply follow the instructions in your manual for removal proceedures, its very straight forward and I believe a total of nine screws.
When you reinstall the new cluster you will find that the center connecting plug is no longer used.
It was for the little lights we just talked about, yes you can still clip it in place if you like.
I did just to have the peace of mind that theres not wires bouncing around in the dash.
Step 3: Pedal Swap & Clutch Master Install
First let me say dont be cheap and try to cut your current brake pedal down to size, it's really not that dificult to swap if you are going to already be into the clutch pedal and have the proper brake pedal handy.
To remove the setup remove the 14mm nut to the left of the clutch pedal, it is connected to the shaft that the clutch pedal rides on, now go to the right of the gas pedal and pull the bolt out, sometimes it helps to tap it from the clutch side.
You will now see why I said dont be cheap on the brake, The brake and clutch ride on the same shaft.
after you have removed it you can remove the return spring and master cylindar connected to the clutch pedal, dont bother removing the rod from the clutch pedal, just pull it right out of the master cylindar with the clutch pedal.
For the brake pedal you will need to remove the lock ring and rod connected to it, now you can remove its retun spring and the pedal.
The clutch pedal has two electrical actuators for what I'm guessing would be the some sort of anti after burn like on the first gens so you dont backfire in between shifts and they other would be the switch that doesnt let you start unless the clutch is pressed in.
Either way, you can mount them both but there are no connections to hook them up to, so just toss them.
When you start your installation you will use the Bolt from the manual pedal setup, it is longer for the clutch pedal.
Remove the clutch master cylindar block off plate and reverse all steps above and you are in buisness, if you run into trouble or lose the order in which your assembly goes back together you can always count on your trusty manual to help see you through it.
Step 4: Rear End Swap
You should definetly swap out your rear end, unless you want more top end and less torque and low end?
Make sure you have a floor jack under the Rear end Throughout most of this process.
Dont forget to remove all exhaust equipment and heat sheilds from the downpipe to the rear Y pipe.
Disconnect the drive shaft from the rear end on the manual trans donor car.
To remove the rear end remove the rear half shafts from the center pig, just remove all four 14mm bolts on both sides and wiggle them loose.
Now you can remove the two bolts that hold in the rear of the pig.
now come around to the front of the pig and put down your haynes manual, you see the three bolts they want you to remove are near impossible to get out.
Look to the other side of the front mount and you will see two nuts, we will go for those.
Disconnect the rear sway bar from the spindles, follow the main rear end assembly mounting brace to the front and you will see two main mounting points, one on each side, I beleive they are 17mm or 19mm.
First you have to remove the safety brackets that bolt to them, they are 14mm and bolted to the frame, remove them then remove the bigger bolts.
Now the whole rear end assembly should drop enough to get to the two front mounting nuts we talked about on the pig.
You will now remove the little plate that sits right behind where the nuts where.
The rear end now should lift up and out the rear on the car.
When you remove the rear end from the automatic trans car you can leave the driveshaft attached since we will not be using it and it will pull out the back of the car with the rear end and a little brute strength.
Installation is the reverse of removal.
Step 4: Transmission and Flywheel Swap
You will need a 2-1/8 socket, an impact gun and a gear puller.
Remove both transmissions.
Start by taking the flywheel nut completely off then attach the gear puller and tighten it up with a fair amount of tension on the the flywheel, dont worry if it doesnt just pop off.
Now take a nice big hammer and hit the face of the flywheel, but not where the clutch disc rides.
repeat the steps for the balancer on the car that had the auto trans.
Check your pilot bearing before installing the flywheel and clutch disc assembly. If everything looks ok and checks out install the flywheel with the impact gun and install the clutch assembly.
Install then transmission and rest the rear half on a jack.
Swap over your auto trans mounting bracket to the manual transmission "not the body".
Step 5: Reverse Lights and Neutral Safety Switch
Locate the two red wires on the manual transmission, keep them in mind.
Look for a white three pronged clip that used to plug into the automatic transmission, cut all three wires and connect the bottom two together "this will allow you to start the vehicle" and connect the top of the three to one of the red wires on the manual transmission "doesnt matter which one, you will need to add some wire to complete the connection".
Now take the other red wire and run it into the inside of the vehicle through the shifter hole " you will need to add soem wire to complete the connection" locate the wiring harness in the shifter area that used to connect to the automatic shifter assembly.
Locate the 4 pin clip, now locate the black with yellow stripe wire and attach it to the wire you ran inside the car from the transmission "this will allow your revers lights to work".
Step 6: Wrapping up the small stuff
Install your slave cylindar and slave cylindar line.
Remove the passenger kick panel and disconnect the automatic transmission computer marked EC-AT or EAT.
Now would be a good time to plug the open vacuum line on the throttle body.
Step 7: Custom Transmission Mounting Brackets
You will need to cut four pieces of steel out of 1/4 thick steel.
The parts will need to be roughly 1 1/4 wide.
All holes will be 1/2" in diameter.
The finished product will be 2 brackets
1- Cut two pieces 5 3/8 " long and label them "A".
2- Cut two more pieces 4 5/8" and label them "B".
3- On your "A" parts drill one hole 1" in from the edge and another hole 2 9/16" in from the edge, repeat for both "A" parts.
4- On your "B" parts drill One hole 1 1/8" in from the edge and another hole 2 11/16" in from the edge, repeat for both "B" pieces.
5- Now draw a line 4 3/8" in from the same edge you used to measure from for your holes on both "A" parts.
6- Take the oppisit end you measured from on your "B" part and line your "B" part up to the line you drew on your "A" Part.
7- Repeat for the other "A" "B" set.
8- Measure the amount of overlap on both parts "this should be 1" exactly.
9- Measurements from the edge you first measured from on your "A" part to all holes are as followed in order 1", 2 9/16", 6 5/16", 7 7/8".
10- Overall part length should be 9".
11- If all measurements are corret weld each set together.
12- Bolt what was part "A" to the transmission crossmember on both sides with nuts, bolts and lock washers from your local hardware store.
The step in the metal should step down, if you put them on backwards your trans will sit 1/2" lower then it should and will be noticeble, if mounted correctly your trans will sit 100% perfect stock height with near stock strength as well.
13- Use stock bolts or fresh ones from the hardware store to mount the half of the bracket that was the "B" part.
Step 8: Install Driveshaft & Shifter
Install the driveshaft and shifter, Adjust the throttle body to correct idle.
Go out and show off your hard work.
Hopefully this whole writeup will be clear as day, I plan to put up many more writeups in the future since I am no longer maintaining the sevensport club site.
Hope you all enjoy
vqturbo
Old School and Other Rotary
32
Aug 11, 2023 07:29 PM
yetter227
20
Sep 5, 2015 11:57 PM
