MSD 6A Results
Old Jun 24, 2003 | 11:41 PM
JIMMY54's Avatar
GSL-SE PRO
MSD 6A Results
All right guys got it done and been driving for 2 weeks and this is the results.
-Fuel consumption was actually reduced
-corrected my power band, meaning smooth constant acceration throughout the rpms.
-slightly quicker trottle response.
I had to hook it up the directfire method,
NO OTHER WAY WORKS
Had to buy an extra coil. w/holder
Had to change my spark plug wires, be ready to buy a new set of wires cause directfire requires the leading coils to connect to the leading spark plugs and stock wires won't reach. and the 3rd leading coil requires a wire with "male ends" on both ends. You'll need to buy a set of wires you crimp and cut yourself.
Had to custom make a bracket, since I'm a "Pro bracket builder" it was not a problem.
Luckily no wires were extended off the msd, and the box was placed by the cone air filter.
Total cost in "canadian dollars":
MSD box $330
wires $115
MSD coil $90 x3 (you need 3 in total)
A $715 dollar ignition system. Thats what pissed me off cause you never think that you'll need "this and that" to make it work.
You american guys will probably be able to do it for less cuz everything is cheaper over there.
But looking back, it's not much bang for your buck, but I don't regret it. It'd would have been better if I had known what I had to buy all at once instead of running back and forth.
Time..... 5 hours for a clean install.
PS the distributor looks weird cuz some spots aren't used!
Old Jun 25, 2003 | 12:17 AM
Jeff20B's Avatar
Lapping = Fapping
Did you move your T wires to the L parts of the cap?
Also, ah, nevermind.
Old Jun 25, 2003 | 01:19 AM
JIMMY54's Avatar
GSL-SE PRO
nope...
trailing is left how it was
Old Jun 25, 2003 | 01:29 AM
Jeff20B's Avatar
Lapping = Fapping
The L portion of the cap has a carbon button and only one gap for the spark to jump. I suggest moving your wires, but only if you want to.
Old Jun 25, 2003 | 06:31 AM
Lt. Dan's Avatar
90 dollar COILS!??!?!?!?!
Dan
Old Jun 25, 2003 | 08:32 AM
pillage6's Avatar
$90 Canadian.
Old Jun 25, 2003 | 01:12 PM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
$90 canadian is way too much... Which coils did you buy Jimmy?
Old Jun 25, 2003 | 01:34 PM
pillage6's Avatar
It says MSD, probably Blaster 2's.
Old Jun 25, 2003 | 02:20 PM
FB II's Avatar
i paid 90 for three msd blaster 2's here! DAMN!
Old Jun 25, 2003 | 02:21 PM
Northern 7's Avatar
Nice coils but maybe a little over kill. I used Accel's for $50 Can. a pop and they work fine. You could have even left the trailing coil as stock since there is little to be gained by adding a high perf. coil for trailing (although I did too). As for the wires, you probably upgraded to a better wire with this install so you shouldn't really count the wires (you could have bought a couple of coil to plug wires for $10 each). Bottom line is it could have been done cheaper so, in other words, the MSD upgrade does not cost as much as you have quoted (it simply cost you that much with your add-on's) I still think having a decent ignition system (that's done right as you have) is a very important upgrade on these cars
Old Jun 25, 2003 | 04:21 PM
i payed 55$ for (each) brand new msd blaster 2 coils (canadian)
Old Jun 26, 2003 | 12:30 AM
JIMMY54's Avatar
GSL-SE PRO
90 each taxes included..... I bought them at "performance improvements" I know those guys are a rip but I had no choice I needed the car.
Old Jun 26, 2003 | 12:32 AM
JIMMY54's Avatar
GSL-SE PRO
Well anyways I just wanted to let everyone know what is involved and what is needed to complete the setup.
Since msd questions do often arise around here.
Old Jun 26, 2003 | 10:24 AM
racintang's Avatar
Where did you get the distributor? I am wiring up a dual MSD 6A box setup with the MSD coils. MSD recommended not usinf the blaster 2 for rotary engines. The suggested using MSD Blaster DIS Racing Ignition Coils #MSD-8230 (Summitracing.com part#) They are for use with dual coil cars. Anyway, I have not ben able to find any new distributors for a 12A engine. Hook a brother up, Man!
Old Jun 26, 2003 | 11:41 AM
82streetracer's Avatar
8/1 Building/Drive Ratio
i got my blaster 2s for like $15usd each from summitracing.com
Old Jun 26, 2003 | 01:03 PM
Jeff20B's Avatar
Lapping = Fapping
I'm thinking a DIS coil would be best for a rotary, in direct fire mode (which is the way it should be so the CDI sparks don't need to go through the cap). I've got a 6AL that will be used on a streetported engine so I don't over rev it.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
userjh5174
Alternative Fuels
Jan 9, 2016 08:49 AM
dona1326cosprings7
Oct 29, 2015 06:47 AM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
