AutoMeter Gauges in FD Inst Cluster
Old Jun 23, 2003 | 05:45 PM
maxpesce's Avatar
Ex fd *****
I have posted some pictures in the Gallery:
https://www.rx7club.com/photo/showga...13&ppuser=2939
Showing the progress of my project to install 3 AutoMeter "SportComp" gauges in place of the stock oil press, water temp and fuel level gauges. As you can see in the pic's:
I moved the new Fuel level gauge to the old Water temp loc,
The new Water temp gauge (120-250f) in the old oil press location and put a Oil temp gauge (14-300f) in the old fuel level loc. the stock oil press gauge has been replaced by a mechanical 0-150psi SportComp gauge monted on the 'A' pillar along w a SportComp Boost/Vac gauge (visible in the pic of the stock instruments)
The wiring will be tied into the orig harness through the orig flexible circuit board with the Autometer Senders replacing the stock Oil Press Sender & Water Temp sender, The new Fuel gauge will be wired to the stock sender. The Oil Temp sender will be installed in one of FC3S.orgs (http://www.fc3s.org/) NEW fd Billet Oil filter pedestals (replaces the stock unit and provides 2 gauge taps)
Old Jun 23, 2003 | 06:24 PM
jdhuegel1's Avatar
Glug Glug Glug Burp
Very nice work. Looks great!
Old Jun 23, 2003 | 08:05 PM
Mahjik's Avatar
Mr. Links
Damn Max, that's sweet!
That's it, I'm sending you my dash next winter.
Old Jun 23, 2003 | 11:44 PM
Godzilla-T78's Avatar
Very nice bro! Its great to see someone brave enough to do somthing like this. I am thinking of converting to a full digital dash like used in indy
Old Jun 23, 2003 | 11:45 PM
911GT2's Avatar
The Power of 1.3
Looks awesome, very cool idea too. I've thought about things like that but would never dream of attmepting it. Very nice work. How much to do mine??
Old Jun 24, 2003 | 12:11 AM
spooledUP7's Avatar
There and back again
I have always wanted to install an electronic boost gauge with a digital water temp combo into the dash. I know you race a lot, and for you the gauges you chose will serve a purpose, but to me, the boost combo is the way to go.
Nice work!
Old Jun 24, 2003 | 11:18 AM
maxpesce's Avatar
Ex fd *****
Nice work!
Mica:
Check out Max Cooper's site (http://www.maxcooper.com/) he put 2 dual SPA digital gauges in his Inst cluster. and has a good write up on his site.
I hope to have the project completed in time for the July SoCalRX club meet
Old Jun 25, 2003 | 12:17 PM
vudoodoodoo's Avatar
Wow, good job.
Old Jun 25, 2003 | 01:27 PM
jimlab's Avatar
Super Snuggles
Max has great information on his site but it's getting to the point where I'd almost offer to fly up to take clearer pictures for him just so you could tell what was going on.
Old Jun 25, 2003 | 02:11 PM
DomFD3S's Avatar
Mod Powers...gone!
Yeah, Max's site is very informative. But he needs a mini tripod. Also some times, the camera is too close to the object.
Old Jul 17, 2003 | 01:37 PM
maxpesce's Avatar
Ex fd *****
Well I recieved (monday) & installed (wednesday) my new Oil Filter Pedestal from fc3s.org It is a very nicely made polished billet piece w/ 2ea 1/8 npt taps for installing aftermarket gauges, so now all I have to do to complete my Gauge Install is, pull my inst cluster, swap my Tach & Speedo to my modified cluster, add 3 warning lights (for fuel, water & oil level) probably in their own mini cluster mounted on top of the steering column, get all the photos processed & scanned, and finsh a write-up for anybody that wishes to attempt the same.
I could even po$$ibly be pur$uaded do do one for anybody that is interested
Old Jul 17, 2003 | 02:21 PM
r0t0r-rooter's Avatar
call me Smokie Smokerson
Hmm.... would it be at all possible to make the newer 99-spec rz/rs dash's boost gauge functional, or is that just too big a PITA?
Batmobile just bought the instrument cluster, and I think it's a waste of space to have a non-functional guage (not that the stock temp is good for anything).
Old Jul 17, 2003 | 02:25 PM
maxpesce's Avatar
Ex fd *****
I Think the 99 gauge works off the stock MAP sensor bidkfs you would have to check the 99 FSM/ Wire diagrams, If it is a Mech Gauge ( but i doubt it is) just plumb it to the normal place (the extra nipple on the uim)
Old Jul 17, 2003 | 04:21 PM
CCarlisi's Avatar
Rebreaking things
lol.
Good job Max and Max. I was eying the SPA fuel pressure gauge this morning. At $286 a gauge I'm going to have to sleep on it though.
Old Jul 21, 2003 | 03:15 PM
maxpesce's Avatar
Ex fd *****
Well I would be further along BUT getting the Oil Filter pedestal on and having it be LEAK FREE have turned out to be two entirely different things - I will be stopping off at the Parts store for some High Temp Form-A-Gasket on the way home from work today. Hope that will fix it.
Old Aug 4, 2003 | 10:44 AM
maxpesce's Avatar
Ex fd *****
Well I finally got the pedestal on w/o any leaks (turns out the O Ring counter bore was .25mm too deep preventing the O rings from sealing properly, Dave Re-Machined the unit and also added a machined notch for the Bump that is only on the AUTO Bellhousing. Pics Are pending in the Forum Gallery and are posted in the SoCalRX Club Yahoo Group PHOTO section:
http://tinyurl.com/iytl
More updates SOON
Old Aug 6, 2003 | 12:15 PM
maxpesce's Avatar
Ex fd *****
Pics Are in the Gallery (FINALLY!)
https://www.rx7club.com/photo/showga...18&ppuser=2939
Old Aug 25, 2003 | 10:05 AM
maxpesce's Avatar
Ex fd *****
UPDATE:
Well the Gauges are in & the cluster is reinstalled & are all working (more or less) using the stock wiring harness connections. I still have to hook up the lighting for the new gauges and the Fuel gauge needs tweeking - w/ the Stock sender the gauge pointer is about 15deg beyond the F mark when Full and when the pointer shows 1/4 it only takes 9 gallons to fill up (about 1/2 tank)
I think I need to add a small resistor(s) in parallel/series to matsh the gauge range to the sender range better. More pics soon.
Old Aug 26, 2003 | 12:27 AM
artowar's Avatar
FD3SW211E55
Looks great Mark!
Old Aug 26, 2003 | 05:31 AM
WaLieN's Avatar
Call me gramps!
That's an awesome job!
Old Aug 26, 2003 | 10:53 AM
So, how much $$ are we talking for your $ervice$? Have all the bugs been worked out? How long would someone have to leave the car @ your place?
Nothing at the moment though, just some planning. I don't think I can even afford the gas to drive the fd up there
Old Aug 26, 2003 | 06:16 PM
SERIES7's Avatar
Embassador to SOY
Old Sep 8, 2003 | 11:00 AM
maxpesce's Avatar
Ex fd *****
UPDATE
Here are some pictures of the (almost) final product
The nearly completed wiring on back of the cluster
I still have to add some warning lights for low oil, coolant & fuel - They hook up to the 3 pairs of terminals I added to the flex circuit where the orig bulbs went.
Complete cluster ready to go back in the car
Modified cluster installed in car
Also I need add some resistors to the fuel sender wiring to match the sender (7ohm F -76ohm E) range to the gauge (10ohm F -73ohm E) range I figure it will take 1 3ohm resistor in series w/ the gauge to get the Full reading right and a 900 ohm in parallel to get the Empty reading right.
I will also be adding a seperate Dimmer for the autometer guage lighting so I can match their brightness to the stock lighting.
Old Sep 8, 2003 | 11:41 AM
maxpesce's Avatar
Ex fd *****
I have not thought about pricing yet Or am I even sure I want to do this for other people.
IF I do, do this for others, I would NOT need (or WANT as I have NO pace to store sombody elses car, I barely have room for my 3) the car, just the Instrument Cluster. Let me know what you all think this would be worth to you and I'll consider it
Old Sep 8, 2003 | 02:13 PM
alberto_mg's Avatar
how about a pic of the setup at night? I'm curious how the autometer gauges will look at night. Very nice thread though
