Sponsored by: CARiD
idle prob on rebuild
Old Jun 22, 2003 | 05:38 AM
PPC-Racing's Avatar
91, na, auto.
havingnsome issues with idle, it feels like thiere's something sticking but when I've checked out the mechanical linkages they are all moving smoothly, it seems I can duplicate the problem by moving the 2nd throttle adjuster against the TPS sensor associated with it. it's almost as if the TPS sensor is sticking ? is this a common thing, indicative of a TPS needing replacement or something else..
Old Jun 23, 2003 | 03:59 PM
Cosmo Donk's Avatar
Queer
Does the TPS feel like it is sticking? They should move in and out without a problem.
Does it happen the instant it hits the TPS?
I would go ahead and measure the resistance of your TPS. I have a How-To on my website.
-E
www.rx7turbo.com
Old Jun 24, 2003 | 01:49 PM
PPC-Racing's Avatar
I found one other problem that might be lending to some of this poor idle situation, my primary injectors are leaking like crazy, I'm dropping from 41 psi to 0 psi in 15-20 min.. fuel is dripping fown the engine for pete's sake! I checked the archives for a consensus fix for this but didn't come up with anything, I've ordered new O rings, isolators and grommets for the injectors with hopes that this will solve the problem. Any other suggestions beyond the fuse /switch hack that seems to be what most people do ?
Old Jun 25, 2003 | 04:21 PM
Cosmo Donk's Avatar
Queer
Dayum dude!!! That's some LEAKAGE! I would send out, or bring to your favorite diesel shop, your injectors for a thourough cleaning. www.rceng.com is $25/inj and blueprints them for you. That's the only way to fix them. You could install a cut off switch but that, obviously, is only temporary, well not a real fix anyway
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
