Sponsored by: CARiD
freakin headllight ain popup
Old Jun 19, 2003 | 02:04 PM
Roar 629's Avatar
Unhappy freakin headllight ain popup
it was gettin late. so i turn my headlight on, when i turn the lite switch.. the light did not pop.. i tried couple time more < still didnt work..> then i tried button to get the headlite pop .. it pops when i push da button can anybody tell me wat's wrong w/ my headlite..now i have a stupid curfew..
Old Jun 19, 2003 | 05:43 PM
Project84's Avatar
Open up! Search Warrant!
Check fusible links, relays, fuses, and then the switch. You can manually cran the motor up by using the **** underneath. Then turn the lights on and off. When you turn them off, the light should go down. If it works in one direction and not the other, that should help isolate the problem.
Jesse Cardinal
Sep 20, 2015 06:31 PM
Sterling
27
Jan 4, 2002 11:21 AM
