indeglo gauges
Old Jun 18, 2003 | 07:36 PM
indeglo gauges
i have some for my 88 fc n|a and i was woudering a good place to put the power red wire? so that it comes on only when i turn the light ***. so my gauges turn on the same way before when it was stock!
thanks
Old Jun 19, 2003 | 01:11 AM
comon 1 person must know a good + wire i can tap into
Old Jun 19, 2003 | 08:11 PM
omg this is the first post that i have not yet got an answer to. hahhaha and i know its only like 10 posts but i was on another name before!!
Old Jun 20, 2003 | 12:21 AM
poweRX-7's Avatar
i will go ahead and post here out of pitty... but i don't know the answer either. sorry
Old Jun 20, 2003 | 01:27 AM
racerfoo's Avatar
try the ash tray light if you have one...thats where i hook everythin up...but i have an FD.
Old Jun 22, 2003 | 07:59 PM
rajeevx7's Avatar
2 FD's since '98
got pillar guages?
mine run off my extra guage lights.
raj
Old Jun 23, 2003 | 06:03 PM
bravebluerx's Avatar
bravebluerx
Loosen the instrument cluster plastic surround so you can get to the headlight switch and jump into the wire that is hot when your parking lights are on. Download the rx7 wiring diagram and find out which colored wire/colored stripe that is or use a test light. I don't remember what it was off hand. If you dont have a front left 4" dash speaker, mount the indiglo gauge electronics in there and then you can feed the color changer out that speaker grill.
Old Jun 26, 2003 | 08:39 PM
ajsuper7's Avatar
Nothin But a G Thang
i just installed my reverse gauges a few weeks ago with the same problem, i solved it by using the ash tray light wire...works perfectly
The1Sun
Sep 18, 2015 07:13 PM
kryan9
Sep 15, 2015 10:11 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
