Boost problem through transition!!??!?
Old Sep 6, 2001 | 11:24 PM
Pressurized's Avatar
Question Boost problem through transition!!??!?
okay, let's see if anyone can help me here....
I'm getting low boost through the transition, 8psi as opposed to 12psi....
Here are symptons that I can relate to this.....
My primary turbo spools slowly, about full at 3400rpm?
Sometimes the primary doesn't get to 12 psi, but the transition is always 8?
When I "get on it" at a lower rpm I sometimes get a BIG hesitation?
Could any of these be a possible symptom of a problem? I've checked most of the connections and vacuum lines and I don't know what else to look at. What happens between the turbos that could cause a problem?
rgordon1979
40
Mar 15, 2022 12:04 PM
sherff
Sep 12, 2015 12:22 PM
AXA
Sep 5, 2015 10:06 AM
tiger18
Sep 3, 2015 08:27 PM
rx7shirley
Sep 2, 2015 02:11 PM
