rattle can job
Old Jun 11, 2003 | 04:20 PM
rattle can job
next weekend i'm gonna be putting on my bonez race pipe, corksport cat back and i'm gonna be attempting a rattle can job. i was wondering if anyone has been successful with doing this and if so any warnings. i tried doing a search and i've seen some kids saying they're gonna do this but no pics of it finished. well anyway it should be a fun weekend project and i'll post before and after pics of both projects when i'm done
Old Jun 11, 2003 | 04:28 PM
1987RX7guy's Avatar
Eat Rice Don't Drive it.
whats a rattle can job?
Santiago
Old Jun 11, 2003 | 04:29 PM
spray paint, i'm gonna go flat black like on that silvia that was featured in SCC
Old Jun 11, 2003 | 04:31 PM
ViperKillerWannabe's Avatar
Resident Moonwalker
rattle can = rustoleum or some other spray can paint
Old Jun 11, 2003 | 05:22 PM
Icemark's Avatar
as far as the spray paint, make sure you wipe everything down with some prep sol or some sort to remove all the old wax and oils in the existing paint.
A quick sand with some 800-1200 grit before spraying probably would be a good idea as well.
Old Jun 11, 2003 | 05:43 PM
CANRX7GX's Avatar
PREDATOR
i did a rattle can job on my headlioght cover and THE FRICKING DUST AND CRAP THAT GOT ON IT WAS A NIGHTMARE, but i used some super fine sandpaper and did about 3 applications, then sanded it down befor the rattle can clear coat. it turned out pretty damn good for a first time haha goo dluck
Old Jun 11, 2003 | 07:35 PM
Rob XX 7's Avatar
FC guy
you could also wash the car with a fine scothbrite pad and soapy water ( DAWN dish detergent is pretty good, DuPont actually reccomends it ) to prep the car and to remove any grease.
This is also how MAACO does it by the way. Scuff pad and some comet.
Old Jun 11, 2003 | 08:05 PM
cloead's Avatar
sold--no longer in debt
That car that was in SCC lookd pretty badass.
Old Jun 11, 2003 | 08:20 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
Flat black is easy. Lots and lots of light coats. Buy like $50 of flat black, and go back and buy more if you run out.
Old Jun 11, 2003 | 08:24 PM
jon88se's Avatar
Eat, sleep, work, mod.
hmmmmmm cool for someone elses car...i can't drive a flat black car everyday.
Old Jun 11, 2003 | 08:32 PM
Drifter101's Avatar
Back from the dead...
Go for it, id like to see how it turns out so i can look into doing it myself either that or i attempt to spray it myself
Old Jun 11, 2003 | 09:36 PM
Mark'sMazda's Avatar
stop stealing my avatar
spray in a irregular pattern. You will get stripes if you spray the "proper" way
Old Jun 11, 2003 | 09:52 PM
Terrh's Avatar
That's flat out wrong. Just dust it lightly and do it many many times. I spraypainted my fender with auto touch-up paint, there's no stripes. KEEP YOUR DISTANCE.. I stayed 8-12" away minimum...
Going in an irregular pattern certainly won't hurt things, though....
Old Jun 11, 2003 | 10:35 PM
PJ-4.2L's Avatar
Don't spary too far or you'll have dry spots...
Guys, if you're not gonna give complete advice, don't give it.
I black primered my RX-7 before I painted it... It looked tight for $50 worth of primer/sealer!
PJ
Old Jun 11, 2003 | 11:18 PM
StarionX's Avatar
Don't know about 'easy'... it took me a number of weekends to completely paint my rex (see my avatar)with spray cans (flat black too ).
The great thing was that whenever I would get any paint chips, I'd just use the ol' spray can again.
NZConvertible's Avatar
I'm a boost creep...
You guys like flat black?
Must be an American thing. The only cars that get painted matt black over here are beaten-up old heaps of junk...
Old Jun 11, 2003 | 11:24 PM
StarionX's Avatar
Well I'm an aussie, And I think that matt black is the best, but it has to suit the car. My Series 1 had a porsche 944 kit on it, so at night, it just had that stealth bomber look about it (no reflection).
Old Jun 11, 2003 | 11:25 PM
Resident Moonwalker
It has a certain purposeful look to it. It says, "I spent all my money under the hood so I don't have enough for a paintjob."
bingoboy's Avatar
Lava Surfer
the price is right .
Old Jun 13, 2003 | 09:16 AM
i was wondering if anyone knew about using bondo and like how long it takes to dry and what not. i'm gonna fill in some small dents/dings with this and mold the side skirts to the car using it and wanna know how much time i'll really need to let this sit before i start to paint. thanks
Old Jun 13, 2003 | 10:52 AM
theonlygreat's Avatar
bondo is the easiest thing in the world. mix some grey stuff (bondo) with some red stuff (hardener) and apply to need area with moderate pressure. the more hardener you use the faster it hardens. don't use too much though, it will become un-useable pretty quickly... a matter of minutes. then about 30 mins until you can start sanding it. really simple stuff. just read the back of the bondo can and you shouldn't mess it up.
Old Jun 13, 2003 | 11:01 AM
sweet i was hoping it wasn't something i had to wait a few hours to dry. i wanna get all the preping done in one day and then paint the whole car the next day. thanks
Old Jun 13, 2003 | 11:37 AM
steviep_'s Avatar
me and 2 friends completely black primered his truck in under half an hour and it cost under 14$
u just need to scuff all the paint with a fine grit sandpaper if u get ne on the windows u just have to use an sos pad and it will come off like nobodies buisness i also painted my winter beater this way amazingly easy cheap and fast
just try not to get any runs they are annoying to get out
thin light coats is the trick
and if u can do it somewhere where there is no wind
i painted my car on my driveway and its no cakewalk when ur paint isnt hitting the car and its like 6 inches away
anyways i hope this helped
steve
Old Jun 13, 2003 | 12:28 PM
i am actually painting my car in my garage because i figured any wind would make it a bitch to paint. but it's good to know about getting anything off the window, hopefully i'll do a good enough tape job where i don't run into that. i can't wait to do this, only 7 more days.
breakfast
Sep 20, 2015 07:06 PM
Rotospectre
Sep 13, 2015 11:22 PM
