Ready to buy true HID Kit is this it?? link inside
Old Jun 11, 2003 | 11:42 AM
West TX RX-7's Avatar
Da Monee Pit
http://www.imotorgear.com/product.as...d=15100100P002
Is this the kit that will replace my factory headlamps? If not can anyone direct me to a site that has a direct replacement HID lamp kit? I want the real ones.
Thanks!
Old Jun 11, 2003 | 12:08 PM
Black13B's Avatar
In Full Autist Cosplay
the housing from this thread may interest you..
https://www.rx7club.com/forum/showth...ight=projector
Old Jun 11, 2003 | 12:27 PM
Da Monee Pit
Is the factory FC headlamp size 200mm? I'm interested in a hella lense then go with an HID conversion if that'll fit better.
Old Jun 11, 2003 | 12:35 PM
jon88se's Avatar
Eat, sleep, work, mod.
I have true HID's w/ the hella offroad lamp housing...can you say bright headlights? the lines are so crisp and sharp and well defined...one side of the line these lights draw is BLACK (night) and the other you'd swear is day time hehe
Old Jun 11, 2003 | 12:41 PM
Da Monee Pit
What exactly did you get? The Sylvania kit? X6054 sealed beam HID replacement 200mm 5X7? I'm looking more for performance over the blue color. 4300k I understand makes the truest white light and best visability and thats what I'm after.
Old Jun 11, 2003 | 01:05 PM
Da Monee Pit
Thanks for the link Black. It gave me some ideas and some search tips. I ended up buying a sealed beam Sylvania system for 439.00, regularly 899.00 so not a bad deal. heres the link I found em at.
http://www.xenon-hid.com/Headlights-sealed-beams.htm
I'll let you all know what I think of em when I get em installed.
Old Jun 11, 2003 | 01:43 PM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
True, well made HIDs are incredible. The cutoffs are AMAZINGLY sharp. Above the cutoff, looking directly at the light, it doesn't appear to be very bright at all. 1" lower and you can't see, because you're blind, theres so much light. It's just incredible.
I'd still like to find a HID system with HID high beams, though.. HID low beams + regular high beams is retarded... And no high beams at all is even worse.
Old Jun 11, 2003 | 03:34 PM
Da Monee Pit
Agreed, HID lows and reg high is gay but I rarely use high anyway. Anything is better than the factory yellow sealed beams or what I am running now, cheap *** e-bay hid lookalikes.
ChrisRX8PR
Aug 21, 2015 01:56 PM
RaY358
Aug 19, 2015 11:44 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
