Final verdict on Apex-i AFCs?
Old Jun 10, 2003 | 03:42 PM
sublime42o's Avatar
I have heard lots of people say that a V-AFC will not work on an rx7 but I have also heard lots of people say that it will, and does work on an rx7. My car is an 89 GTU and I just ordered a V-AFC thinking it would work fine. Do I need to send it back or sell it to someone because it will not work, or is it exactly the same as the S-AFC just also with a v-tec controller?
Thanks
Tom
Old Jun 10, 2003 | 04:16 PM
vectorminds's Avatar
Where's My Fuel???
why did you order a v-afc over an s-afc... there is nothing for it to control (unless maybe you got it to control your 6th port and vdi selnoids... but im preety sure they already come on at the best times), and i dont even know how you would wire that up
what where your reasons for getting the v-afc over the s-afc?
Old Jun 10, 2003 | 04:45 PM
NZConvertible's Avatar
I'm a boost creep...
The V-AFC has been designed specifically to interface with Honda ECU's. It's V-TEC control fuction would not work with any other manufacturer's ECU. Send it back and get the S-AFC.
Old Jun 10, 2003 | 09:17 PM
sublime42o's Avatar
well i dont want to use the vtec option, but I found a V-AFC on ebay for $228 and all the S-AFCs I saw were upwards of $300. Will the V-AFC work at all on my car? I dont want to use the vtec actuation for anything.
Old Jun 10, 2003 | 09:18 PM
Scott 89t2's Avatar
SOLD THE RX-7!
it doesn' work as you can't select the AFM sensor. it only works with honda map sensors.
Old Jun 10, 2003 | 10:29 PM
Where's My Fuel???
there are s-afc's on ebay for around 225 last i checked... you just probably found the version two ones... with the 12 bands of adjustment... the earlier ones (which i belive are the same as the v-afc without the vtec stuff) have 8 bands, and are much cheaper... like i said around 225 - 235
Old Jun 10, 2003 | 10:30 PM
theonlygreat's Avatar
yes, it will not work. it is made for the specific honda/acura applications. i installed one in my friends del sol and it had very specific directions which would not translate to other makes of cars.
Old Jun 10, 2003 | 10:50 PM
Z3r0's Avatar
it worked on my car... but I would send it back and get a safc... I jus used a vafc becuase it was in my hands (used to have a honda). I have the sensor type set to in 5 out 5. I dunno if its something with the wiring but + is lean and - is rich. Sounds stupid I know.. and when I get the money I am gonna get a safc too.
Old Jun 10, 2003 | 11:24 PM
marcus219's Avatar
FC Mobsta
Sure that its actually "working"?
Old Jun 10, 2003 | 11:29 PM
There's been a few for sale brand new on this forum for under $300.
Z3r0's Avatar
I am using it to run my car with TII injectors right now
Old Jun 10, 2003 | 11:33 PM
Kanaida's Avatar
I'm surprised that you can get any type of control of a vafc on a 7. Purely designated for Honda ecu's and all.. I'd be very untrusting of it if you did find some way to wire it up and use it.
-K
Old Jun 10, 2003 | 11:36 PM
Z3r0's Avatar
the wiring is pretty much the same, with exception of vtec signal from what I can remember and I think an extra ground wire.... again... this is not a pernament solution for me, mostly due to lack of funds. and again I would go get a safc which is what I wanna do when I get a litto extra cash and sell the vafc. Also I would advise the guy who started this forum to get a safc, save yourself the trouble ^_^
Old Jun 11, 2003 | 12:41 AM
sublime42o's Avatar
haha well damn... thanks guys
Coochas
44
Nov 5, 2019 11:08 PM
23Racer
Canadian Forum
13
Nov 25, 2018 04:44 PM
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
airjordan223
24
Oct 4, 2015 04:42 PM
