New to this boost thing---I Need some help
Old Jun 10, 2003 | 12:13 AM
kleach18's Avatar
Just Looking Around
I just got a boost guage. I installed it and ran it from a vacuum sorce that was just caped off. I used the crapy plastic hose they supplied. Now the question is what exactly is the boost guage supposed to read at idle and rpm and how much boost would it be running with a streetported turbo II motor? The only thing done to the turbo was I removed the aux thing that was opened up via vacuum source(I got rid of the source). And matched the size of the two holes going to the turbo(stock s4 turbo and manifold) Any info would help thanks...
Old Jun 10, 2003 | 12:27 AM
Scott 89t2's Avatar
SOLD THE RX-7!
with a street port probably around 15" of vacum.
where did you tap in? it's need a be a vac / boost source after the TB. some are not.
Old Jun 10, 2003 | 12:31 AM
kleach18's Avatar
Just Looking Around
It is on the back side of the upper intake manifold..... Liek right below the bac valve. I have block off plates for all the emmisions stuff(everything is blocked off except the bac valve.) but a nipple for the pressure sensor and one left over that I blocked off until I installed the boost gauge.
Old Jun 10, 2003 | 12:41 AM
kleach18's Avatar
Just Looking Around
At idle it reads like 10(below the 0 PSI) then when I let off driving I get like 20. It says when I'm accelerating that I am running like 13 PSI at 4k RPM.
Old Jun 10, 2003 | 12:51 AM
kleach18's Avatar
Just Looking Around
Anybody????
Old Jun 10, 2003 | 12:58 AM
kleach18's Avatar
Just Looking Around
Anybody????
Old Jun 10, 2003 | 01:08 AM
garlandrx7's Avatar
USMC
go to bed and ill tell you how to fix it tomorrow! sleep is good!
Old Jun 10, 2003 | 01:12 AM
kleach18's Avatar
Just Looking Around
And my exhaust is straight through 3in all the way to straight through 3 in mufflers....
Old Jun 10, 2003 | 01:15 AM
Scott 89t2's Avatar
SOLD THE RX-7!
10 is a little low. might have a vac leak.
how many miles on the engine? if it's brand new then it'll get better.
Old Jun 10, 2003 | 01:19 AM
kleach18's Avatar
Just Looking Around
Its brand new with less then 3000 miles on it, it just needs to be tuned so it idles really low like 300 to 400 rpms
Old Jun 10, 2003 | 01:20 AM
kleach18's Avatar
Just Looking Around
Also when I hold the pedal so it idles where its supposed to be it reads like 15InHg(or whatever is is called)
Old Jun 10, 2003 | 01:21 AM
garlandrx7's Avatar
USMC
my bad, i thought it had more than that
Old Jun 10, 2003 | 01:49 AM
TheBigOne's Avatar
Same as mine
when im at idle i get about 10 below. when i gas it goes down a bit to like -20 then at about 4k i get about +10 lbs boost. i tapped in to a vac line from the manifold.
Old Jun 10, 2003 | 02:38 AM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
just curious but why would you want it to idle so low?
Old Jun 10, 2003 | 03:17 AM
garlandrx7's Avatar
USMC
he doesnt want it to idle so low... "it just needs to be tuned so it idles really low like 300 to 400 rpms" and "when I hold the pedal so it idles where its supposed to be......"
Old Jun 10, 2003 | 08:30 AM
RylAssassin's Avatar
Umm did you guys miss this? Hes running 13 psi at 4k? This is a little high dont you think?. Yes Kleach now you have entered into the realm of boost creep with that open exuast... Not good needs to be fixed. IF your hitting 13psi at 4k then what are you hitting at 6k? Its prob gonna be like 15psi and you dont want that on a stock turbo. Id say max is 12psi and thats still a little high. Just keep in mind this **** can make your engine go pop, did you upgrade you seals at all? Im just lookin out for ya thats all. Make sure the wastegate is operational and that youve ported them well enough.
Old Jun 10, 2003 | 08:36 AM
Rob500's Avatar
"The only thing done to the turbo was I removed the aux thing that was opened up via vacuum source(I got rid of the source). "
Did you remove the wastegate actuator?
Rob
Old Jun 10, 2003 | 10:54 AM
sectachrome's Avatar
pistons=teh suck
whats boost . yes, i am an idiot.
Old Jun 10, 2003 | 11:06 AM
Jaared's Avatar
Ahhhhhhhh hhh....
Rob
I hope he is talking about the twin scroll and not the wastegate.
Old Jun 10, 2003 | 12:43 PM
dr0x's Avatar
pei > caek
I would explain 13psi at 4000rpm
Old Jun 10, 2003 | 01:56 PM
Scott 89t2's Avatar
SOLD THE RX-7!
15" at correct idle is fine... that is what I said in the first post. so it's fine.
ignor the vac at 400 RPM is means nothing...
you should have given more info in the first post. it would have made things so much easier.
but yes the 14psi is too high. don't floor it untill you get some more fuel.
Old Jun 10, 2003 | 02:33 PM
kleach18's Avatar
Just Looking Around
just removed the twin scroll not the wastegate. I don't think its actually runnning at 13 PSI, I think that something is hooked up wrong. i havent taken it above 5k yet.
Old Jun 10, 2003 | 02:48 PM
dr0x's Avatar
pei > caek
What type of boost gauge is it?
Old Jun 10, 2003 | 11:09 PM
kleach18's Avatar
Just Looking Around
Some cheap Type X racing gauge i bought off of ebay, maybe thats the problem??
Old Jun 10, 2003 | 11:18 PM
marcus219's Avatar
FC Mobsta
Speaking of boost guages..how come I hear people ******* on Auto Meter boost guages? Auto Meter makes good quality stuff as far as I know...is it b/c its not made my blitz or hks or.....?
