guage question?
Old Jun 7, 2003 | 02:04 AM
guage question?
Getting a power fc very very soon and was also going to install at the same time a boost gauge, egt gauge, and turbo timer. The question that I have is with all the research that I have done I am still looking to see if anyone makes a dual a pillar pod for 2 60 mm gauges and also if anyone makes the center speaker dual pod for 2 60 mm gauges if anyone knows of it let me know thanks for the help.
Old Jun 7, 2003 | 02:22 AM
One last thing what guages are you guys running trying to find ones I like all by the same company with all of the guages that I need.
Old Jun 7, 2003 | 02:23 AM
rynberg's Avatar
An EGT gauge is pretty worthless IMO. Also, I would just get 52 mm gauges. You can see them just fine. A turbo timer is also a waste with these cars, IMO.
If you are set on using 60mm gauges, you can just dremel out the autometer a-pillar pod. For a center-speaker gauge pod, contact Frank at http://hometown.aol.com/flyrx7/Rx7-Gauge-Pod.html . He makes 60mm pods and his pods are well made.
I run the Defi Link series gauges. They are wonderful, with great accuracy, features, and build quality. They are also the only Japanese gauge available in english units.
Old Jun 7, 2003 | 12:27 PM
look around and see
Old Jun 7, 2003 | 06:39 PM
HWYKING's Avatar
Right an EGT gauge is a waste it only tells you how hot your EGT's are and nah thats not important when your racing around it might only save you a motor, or two..
Old Jun 7, 2003 | 07:06 PM
Yes it is useless. That's what a wideband O2 is for. (lean=hot gases)
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
gabescanlon
Sep 5, 2015 12:09 AM
