HELP - Motor Suddenly Running Rough
Old Jun 6, 2003 | 09:29 PM
RX7Elmo's Avatar
Exclamation HELP - Motor Suddenly Running Rough
Thanks for those that take the time to read this and help me out. IF you could give me some insight on what to check etc, it's appreciated
I was coming off the freeway (was running perfectly fine) and all of a sudden, the vacuum gauge is going crazy and there is almost no power to the motor. I then limped the car back home.
I've done a quick check and looked at the vacuum hose i could see including the map sensor hose and those look fine. At idle, the motor runs really rough, but above 2K the motor is a bit smoother, but of course not to normal specs.
For some reason, i'm ruling out the apex seal b/c i wasn't driving hard, just regular freeway (coasting downhill).
I'm thinking it could be either a lose vacuum hose somewhere (under the UIM possibly) or it could be very dirty spark plugs or a bad wire or coil. My plugs are about 5K old.
Specs on Car.
Reman Motor (30K+ miles) with about same mileage
stock twins turbos.
Mods are Full Exhaust< ECU, IC, basically all the bolt ons and i'm only running 10psi.
Thanks for any help.
Old Jun 6, 2003 | 09:54 PM
potatochobit's Avatar
your throttle body moving when u pull on the cord? check all piping from turbo bov may stuck open.
Old Jun 6, 2003 | 10:25 PM
paw140's Avatar
How would a stuck BOV cause a poor idle?
I've heard that leaking injectors can cause a problem like this. If I were you I would do a compression test first, because your symptoms sound really close to a blown apex seal.
Old Jun 6, 2003 | 10:31 PM
RX7Elmo's Avatar
thanks for the responses guys. I think tomorrow, imma go and do a nice visual search of all the plugs and hoses. If that doesn't check out...imma do a compression test using my ghetto comp tester for pistons or just do it by ear. The car itself does have over 100K miles on it..i don't doubt the fuel injector or the coil coulda gone bad.
Danny
Old Jun 7, 2003 | 01:56 AM
neevosh's Avatar
The Dude Abides
On MAF equiped cars(like FC's), major vacuum leaks will cause a rough idle. However, FD's use MAP sensors. I've ran my car without any IC piping.
Old Jun 7, 2003 | 02:41 AM
RX7Elmo's Avatar
yeah, but i think a lose hose somewhere in the rats nest could cause a rough idle. If worse comes to worse..i'll bring my car to ivan for him to check it out etc.
Old Jun 7, 2003 | 03:36 AM
BicuspiD's Avatar
Infamous...Butcher...
DOh
82streetracer
Haltech Forum
11
Mar 11, 2019 05:34 PM
PhillyFC
Aug 21, 2015 06:36 PM
meat_whistle
Aug 12, 2015 08:41 PM
