Question about a code and what it means
Old Jun 6, 2003 | 08:04 PM
AMRAAM4's Avatar
twinturboteddy ws my idol
Question Error code 16 and what it means
OK guys, been getting an occassional check engine light in the car. I just checked the code via paper clip method and got Code 16 - "EGR Switch open or short circuit"
Seeing that my knowledge is limited, can anyone tell me how serious/not-serious this is? Car has 63,500 miles and is a 94. I have been told it needs a new LIM gasket if that may make a difference. Thanks guys!
Old Jun 6, 2003 | 08:50 PM
legal-z's Avatar
12th son of the lama
i had the same problem. if you take off the coupler that goes from the y-pipe to the intercooler, you should see a little blue plastic piece that has two wires running into it. my wires were loose and slipping off the connection and then causing the check engine light to come on. try that first. if you have trouble finding it, let me know and i'll snap a picture tomorrow.
andy
Old Jun 6, 2003 | 08:58 PM
AMRAAM4's Avatar
thanks man...I won't get to check it for a few days, weekend here is suppose to be CRAPPY and I live in an apt. If things don't work out I will PM you.
Old Jun 6, 2003 | 09:54 PM
MR_Rick's Avatar
Planning my come back
I have a blue plug hanging loose around that area, behind the alternator, where that goes?
Old Jun 6, 2003 | 10:23 PM
paw140's Avatar
The EGR code is very common. It could be a bad position sensor, or it could actually be a bad valve. A lot of people block them off and unplug them. This is a problem with Cali cars because unplugging them will set the check engine light. There are some fixes for getting around that. If you search you should find them.
I've been driving around with an EGR code for the past 1 1/2 years and it hasn't been a problem, except for the annoying light.
Old Jun 6, 2003 | 10:29 PM
paw140's Avatar
https://www.rx7club.com/forum/showth...threadid=21848
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
ZacMan
Sep 19, 2015 09:20 PM
yetter227
20
Sep 5, 2015 11:57 PM
