Interior swap done, dummy lights acting up?????
Old Sep 5, 2001 | 10:48 PM
Ridge Tech's Avatar
this is going to **** you off, it sure as hell made me mad. you need to remove the dash again. take the wireing harness off your 87 dash and put it on the 91. i made that mistake. you also need to retain your 87 dummy lights. there is also a ground that has to be disconneted from the dash, there is no place for it on the 91 so you'll have to run a wire to another ground some were. message me if you have any more questions. I switched my 87 TII for the black 91 GTU interor. Chris
Old Sep 5, 2001 | 10:56 PM
haha, i swapped my 86 na with a 91 TII interior.. u'll have to change the harness behind the dash!
OR in THEORY, you could rewire the 91 harness at the ECU.. but trust me, rewiring aint fun
Old Sep 6, 2001 | 01:21 AM
hypntyz7's Avatar
Hmmm...I put an 89 gtu interior in my old 87 T2, it did the same thing. I kept the 87 wiring harness though... Also check to see that you didnt wire up the interior lights at the sunroof wrong, there ar like 4 connectors and they can go 2 different ways. Mine were wrong, and when I opened the door the interior light did not work, but one of the other idiot lights came on. I pulled the e-brake and the fuel light came on. First check the wires for the interior light, and find yourself an 89-91 type idiot cluster and see if thist fixes it. A couple of the lights are in different positions on the 86-8 to 89+, so you need to keep the one that goes with your dash wiring harness.
Old Sep 6, 2001 | 10:12 AM
vaughnc's Avatar
knowledge junkie
I've rated this tread a 5 so they'll archive it.
Good info guys.
Please rate this as well (bottom right corner).
-- Clayton
Jutta_J
Mar 25, 2017 11:24 PM
