How To Disable Stock Security System?
Old Jun 5, 2003 | 10:12 AM
LUV94RX7's Avatar
Oldie, but Goodie
My security system has a mind of it's own and goes off whenever it feels like. It's embarrassing and I want to just disable it.
Thanx,
Ken
Old Jun 5, 2003 | 10:20 AM
ZeroBanger's Avatar
I think there is a fuse for it under the drivers side dash.
but then again, I could be wrong. But I may not be, unless I am in which case I will be.
Old Jun 5, 2003 | 12:17 PM
Alien7's Avatar
i've heard of ppl grounding out certain sensor wires (door, hood) to make the car think that it isn't closed, and therefore won't activate the alarm.
I went the hood sensor route...just disconnected the sensor, and then I shorted the two wires. Now the stock alarm never activates.
Old Jun 5, 2003 | 12:27 PM
r0gu3's Avatar
Boostless FD
When my alarm goes off, my battery dies. Damn alarm wanting to flash my HID's.
Old Jun 5, 2003 | 12:29 PM
LUV94RX7's Avatar
Oldie, but Goodie
Are you saying all I have to do is pop my hood and then lock the doors and the alarm will not be activated?
Ken
Old Jun 5, 2003 | 12:31 PM
r0gu3's Avatar
Boostless FD
My alarm will activate with my hood/hatch open.
Old Jun 5, 2003 | 01:55 PM
n2trbl's Avatar
Pro Drummer!
I too would like to know what to do. A couple days ago the alarm just decided to go off while I was driving. I don't have the money at the time to get a new alarm put in.
r0gu3's Avatar
Boostless FD
While driving? Wow ...
Old Jun 5, 2003 | 02:55 PM
rousu's Avatar
I have never had the alarm trigger on my current gen 3, how do I test it to verify that it is working?
My previous gen 3 used to randomly trigger and then I knew it was working...
Old Jun 5, 2003 | 02:57 PM
ZeroBanger's Avatar
when the hood and hatch are closed and you lock the doors (the passenger door is locked). in about 10 seconds after you lock it you will hear a faint beep. The "Security" light will flicker then. Your light could be burned out so the way to test it is leave the windows rolled down, lock the car. Then about 30 seconds later, reach in and open the car door from the interior door handle. The horn will go off and the engine will be immobilized.
Old Jun 5, 2003 | 03:04 PM
r0gu3's Avatar
Boostless FD
Mine beeps upon locking with only drivers side door open.
Old Jun 5, 2003 | 03:07 PM
ZeroBanger's Avatar
my drivers side door can be unlocked and it will set as long as the pass side is locked.
Those of you with issues, take your drivers side door handle off and take a look at the rods that attach to the lock mechanisms. There are these small plastic sleeves that attach the rod to the mechanism. if you have tears in them or coming off, that could cause your alarms not working correctly.
Old Jun 5, 2003 | 07:51 PM
LUV94RX7's Avatar
Oldie, but Goodie
Well until I figure out how to disconnect it at least I found out it shuts off after 5 minutes. I guess that's better than leaving it unlocked for long periods time in public areas.
Ken
Old Jun 5, 2003 | 09:19 PM
pomanferrari's Avatar
On the front hood lock, remove the hood lock, there is a sensor connector mounted to the hood lock. Disconnect when your alarm is deactiveated and it won't trigger ever again until you hook it back up. But find out why your alarm is acting up in the first place.
BTW, don't try to steal my car, I have a SigSauer P225 trained on it at all times.
Old Jun 5, 2003 | 09:40 PM
911GT2's Avatar
The Power of 1.3
I have guards armed with assault rifles that stand next to my car whenever I'm not in it. One of them comes with me while i'm in the car, and the other follows in an Abrams Tank.
Old Jan 3, 2005 | 10:19 PM
golferfreddie's Avatar
Start D@mn it!!
My security would activate with the hood open, but not the hatch. I disconnected the hatch wire. It was much easier than removing the hood lock assembly. I then had to ground the connection for the car to think the hatch is open. Just a small spade connector crimped on one end of the wire and a round connector crimped on the other end. The spade end fits in the stock connector and then just find a good grounding spot for the other end. Make sure the hatch light is in the on position. When the light comes on, you have a good ground connection.
The only drawback is that you have to leave the hatch light in the off position while it is closed, but will still work if you turn it on when needed.
Hope this helps!
Old Jan 3, 2005 | 10:44 PM
IOJINXOI's Avatar
no one ever really dies
Disable factory alarm system how to:
Remove the drivers side kick panel.
Unplug the white 20 pin connector.
Unplug the white 8 pin connector that is directly above the 20 pin connector.
Reinstall the kick panel.
Viola, Done!
D.
Old Jan 3, 2005 | 11:19 PM
gambit023's Avatar
Viola, Done!
D.
I hear unplugging those wires will cause the passenger side door not to lock and unlock along with the driver's door? Is this true?
Also, the way I disabled my factory alarm is by taking the factory hood pin wire in CPU#2 (Drivers Kick Panel - Brown/White) tapped into it and then grounded it the other end with a ring crimp onto the body.
I tried disconnecting the hood pin switch itself (in engine bay hood latch). This didn't work for me. My factory alarm still would arm itself.
Old Jan 3, 2005 | 11:58 PM
IOJINXOI's Avatar
You heard correct. It never bothered me to reach over and lock it myself though.
Old May 30, 2008 | 07:44 PM
RISEN's Avatar
Are you sure? I unplugged the 8 pin and the 20 pin connector (Didn't have to remove the kick panel) and the door locks/unlocks fine.
Old May 30, 2008 | 07:50 PM
KaiFD3S's Avatar
SINFUL7
Disabled mine that way too and no problems with the passenger side lock..
KaiFD3S's Avatar
SINFUL7
Haha, just noticed this is such an old thread...lol...
Old May 30, 2008 | 07:59 PM
RISEN's Avatar
Yeah, my alarm went off today at 3 a.m., 5:50 a.m., and 7:30 a.m. but I wasn't there. Neighbors got very pissed.
Old May 31, 2008 | 04:33 AM
scratchjunkie's Avatar
sexy no jutsu
wow this is a very old thread! lol zerobanger actually helped me disable my stock alarm half a decade ago and it still works likea charm.
Old May 31, 2008 | 08:06 AM
pakitagn's Avatar
you can just unplug the middle connector on CPU2 and itll disable you alarm... and your non stop blinking seatbelt light if you have that issue too...
