Excessive fireballs out the exhaust and hesitation/stumbling...
Old Jun 4, 2003 | 06:01 PM
Amagi82's Avatar
50+mpg, woo!
Finally got the RX-7 running, flip the switches, hit the start button, and VROOM! she starts up
I removed the OMP, and I'm running pre-mix, and i think i added a bit too much 2-cycle oil, as its smokin a bit, so tell me if thats the problem.
Anyways, I'm getting... excessive.... fireballs out the exhaust, POP-BAM! every so often, lol. And I'm getting a lot of stumbling/hesitation. What should I check to find and solve this problem?
Old Jun 4, 2003 | 06:07 PM
Cody's Avatar
SKELETOR!
Just sounds like you're running rich. Take it out for a spin to clean it out......and see if it persists.....than lean out your fuel a bit.
Old Jun 4, 2003 | 06:47 PM
Amagi82's Avatar
50+mpg, woo!
how do I lean it out?
Old Jun 4, 2003 | 08:44 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
Mix screw on the carb. This is when an air/fuel gauge is nice...
Old Jun 5, 2003 | 01:34 AM
Amagi82's Avatar
50+mpg, woo!
hehe, i actually have an air/fuel gauge lying around here... but I dont really feel like hookin it up... so maybe I'll just play around with her.
If i get it to lean am I going to blow **** up in 3 seconds?
Old Jun 5, 2003 | 01:45 AM
fatboy7's Avatar
Got Boost?
N/A, not likely. Of course if it feels weak, misfires alot, and runs a bit jerky, your way too lean.
Old Jun 5, 2003 | 03:44 AM
REVHED's Avatar
Hunting Skylines
The mixture screw's only for adjusting the idle mixture so it will in no way cause your engine to blow. To adjust it, turn it clockwise (lean) until the engine starts hunting, then back out till it's smooth and maybe another 1/4 turn. You'll know it's too lean if there's a lot of popping or missing on decel.
The backfiring could also be caused by having the timing too retarded or maybe even an exhaust leak.
If it hesitates when intitially opening the throttle it's probably a faulty accelerator pump.
Old Jun 5, 2003 | 06:03 AM
Amagi82's Avatar
50+mpg, woo!
alrighty, cool, I'll give that stuff a shot.
Old Jun 5, 2003 | 12:39 PM
CHEF_EG_1's Avatar
Rollin' coal and 53mpg!
Mine shoots flames every time I let off the gas, and then consequently, every time I get back on it. It's always fun driving through ISU campus, and seeing everybody **** themselves because it sounds like a 12 guage just went off.
Old Jun 5, 2003 | 03:31 PM
Amagi82's Avatar
50+mpg, woo!
hahaha, mine did that too after i removed most of the emissions crap.
And fireballs arent bad as long as they dont hurt performance... and this is hurting performance
Old Jun 5, 2003 | 06:58 PM
Amagi82's Avatar
50+mpg, woo!
well i messed with that mixture thing, turned it about 10 times around, and it didnt change a thing... soooo... ummm.... yea.
Old Jun 5, 2003 | 10:31 PM
Keaponlaffen's Avatar
I want my car to make fireballs too!!
Time for another project on the beater Prelude
Old Jun 6, 2003 | 12:04 AM
Gatorgunner's Avatar
Im amazed no one has suggested that one of your coils is bad. Mine did exactly what yours is doing and I had a bad coil. Check those while your at it.
Old Jun 6, 2003 | 12:39 AM
Amagi82's Avatar
50+mpg, woo!
hmm, I'll check that, maybe a connection is loose on one of them
Old Jun 6, 2003 | 06:47 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Re: Excessive fireballs out the exhaust and hesitation/stumbling...
id say junk it or beg someone to come over with a new mazda wiring harnes and wire the car back the way it was LOL
Sorry had to do it
Old Jun 6, 2003 | 06:48 AM
MIKE-P-28's Avatar
Is that the 4 rotor one ? LOL Just playing, Im bored and cant sleep
Old Jun 6, 2003 | 12:00 PM
msimonov's Avatar
OGTA
gatorgunner
What other symptoms did you notice? On my car the secondaries come on late and when I release the accelerator the engine will continue to rev. Like there is unspend fuel in the carb/engine. All this went away for about a week when I hollowed out my cat. The car ran great - for about a week. Now it's acting up again.
I did notice one of the coils metered a little low. How did you confirm the coil to be bad?
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
FührerTüner
Sep 4, 2015 01:41 PM
