Hesitant Sunroof
Old Jun 4, 2003 | 12:59 AM
rousu's Avatar
Hesitant Sunroof
The open/close works,
but is sometimes hesitant or requires a hand push/pull to get it moving. A couple times I could not make it power closed. It seems the rails are lubed and things are aligned right.
Are there any hints on giving it more oomph?
Stiffening up the slip clutch? if it has one...
Better electrical current and contacts?
Lube with super lube?
hammer?
use the air conditioner?...
Old Jun 4, 2003 | 02:52 AM
RX-8's Avatar
I had the same problem earlier this spring. Probably because it was unused all winter. Easy fix, spray some silicone lub spray on the rails and problem solved! IMHO works 10 times better than your standard greese. Just make sure you clean any debris or dirt from the rails first. Works great on the doors too, you can pick it up at your local hardware store. Good luck
Old Jun 4, 2003 | 06:23 AM
poor college student's Avatar
Red Mist
hmmm, i think i need to do that w/ my windows
Old Jun 4, 2003 | 09:39 PM
FDjunkie's Avatar
Had the same situation a year or so ago. Found the sunroof switch's internal contacts sort of 'burnt'. Took the switch apart and cleaned the contacts with fine file. Has worked great every since.
Old Jun 5, 2003 | 12:35 AM
RHS's Avatar
RHS
Mine was the same way when I first got my car. I cleaned and greased the rails, work great now.
Old Jun 5, 2003 | 01:37 AM
Echoratz's Avatar
Is that thing a Miata?
i dont mean to be rude or anything but wasnt this car on ebay?
Old Jun 5, 2003 | 09:21 AM
Is your camera's color balance off, or is that really a purple 7?
Old Jun 5, 2003 | 05:34 PM
rousu's Avatar
The Ebay connection is right...
$6000 dollar paint job, and been putting a car back under it.
It is colorshift paint, I think it is Dupont's colorshift, but I do not have records.
Green at noon, purple at twilight, black at night?
-Kameleon
Coochas
44
Nov 5, 2019 11:08 PM
dona1326cosprings7
Oct 29, 2015 06:47 AM
Coochas
Oct 3, 2015 04:49 AM
