Right side door window problem
Old Jun 2, 2003 | 09:26 PM
Here is the problem. my window goes down no problem if i use the switch from the driver side and on the passenger side, but if decide to go up, no go. Now i checked the connector that goes directly to the motor for the right side window and i do get a positive 12 volts and negative 12 volts, so power is getting to the motor and both switches are doing their job. So is it the motor that is shot? it turns one way, but no go the other way. Its kind of weird because if we directly short the connector that goes to the motor, the window goes up. I am stumped. The other thing is, has anyone been able to access the motor for the window? been able to remove it? it all looks like one tightly sealed door, it seems like you would have to replace the entire door because their isnt any indication you can remove part of the door assembly to get to the motor. I would really appreciate some help from you fellow rotor heads.
Old Jun 2, 2003 | 11:16 PM
anybody?
Old Jun 3, 2003 | 02:01 AM
Unhappy
Old Jun 3, 2003 | 04:24 PM
Jeez can't really get any descent help around here.
Old Jun 3, 2003 | 05:20 PM
911GT2's Avatar
The Power of 1.3
Originally posted by TopSecretUSA
I have a simular problem. Both driver and passenger can put down the passenger window but the passenger button wont put it back up. Only the driver can. I dunno what causes it.
That isn't the same problem. RZRX7TT can put it down with either, but neither will put it back up (right?)
I'm replying really just to say "yeah, i read it, but I have no idea, good luck man"
Sounds odd though that power is getting to the motor, the motor works, and it won't work. Seems to defy logic. hmmm...
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
