I think it has bit the dust
Old Jun 1, 2003 | 10:01 PM
Jay Cee 69's Avatar
Newbie
I think my engine has bit the dust... ok here are the symptoms...
.. the plugs are fouled and wet.
when i crank it over weird gas/mystery liquid come out the leading plug hole.. it has the look and smell of solvent... what is it? is the engine dead? can i clear it out some how?
Old Jun 1, 2003 | 10:08 PM
thorin's Avatar
well, it sounds flooded at least.... does it start? does it smoke? what color is the smoke?
Old Jun 1, 2003 | 10:45 PM
Dom's Avatar
Dom
callin' tokyo
When did it last run?
Old Jun 1, 2003 | 11:43 PM
Jay Cee 69's Avatar
Newbie
it doesn't run at all... its flooded and wont become unflooded
Old Jun 1, 2003 | 11:51 PM
Rx7carl's Avatar
Airflow is my life
Sounds flooded not bit the dust.
Old Jun 1, 2003 | 11:53 PM
KYPREO's Avatar
www.AusRotary.com
with the engine cold, crank the engine with the spark plug leads removed.
Then slowly take off the radiator cap. It the system depressurises, (eg bubbles comiing through the overflow bottle), your water seals are gone.
The flooding in that case, is not fuel but water
Try cranking with the spark plugs removed, and the fuel pump fuse removed. That way you can clear out the engine without the flooding getting worse. Do that for a while.
Then clean the sparks, reinstall. Jumper the battery.
Then, when you try and turn the engine over, just keep your foot flat to the floor and crank away.
Old Jun 2, 2003 | 02:49 AM
djmickyg's Avatar
and enjoy this moment. for a few seconds the engine sounds like it bridge ported, and the street will be filled with a lovely cloud of smoke..
Old Jun 2, 2003 | 12:21 PM
TOUGHGUY's Avatar
Got some screws loose!
Is it a manual tranny? If so just get a couple friends and try to push start it. It will turn over faster and be less wear and tear on your starter. I already smoked one starter by cranking and cranking.
Toughguy
Old Jun 2, 2003 | 12:26 PM
Gregs's Avatar
fastest way to unflood a rotary imo is to pour a generous amount of MMO down the carb, or in the plug holes and coat each side of the rotors if your injected
Old Jun 3, 2003 | 07:52 PM
Jay Cee 69's Avatar
Newbie
What is this MMO?
Old Jun 3, 2003 | 07:55 PM
1rx7owner's Avatar
Lifes a garden dig it.
Marvel mystery oil, can buy it at auto zone or any nice auto parts shop.
Old Jun 3, 2003 | 09:27 PM
Bass's Avatar
Grey-Bruce Rotorhead
If it has the manual choke, you should have it in all the way while cranking the engine and then feather it out and in when you feel the motor trying to catch. Then rev the engine good 'till it smoothes out a touch-then set the choke.
If you want to keep the neighbours from complaining about the smoke show run pipes from your tail pipe into a bucket of water. Kinda like a reverse auto bong.
troym55
23
May 25, 2016 12:42 PM
