Fuel Guage
Old May 30, 2003 | 07:10 AM
TheMoonDog's Avatar
Question Fuel Guage
Hi All,
My fuel guage isn't working at all. I was told there is probably a ground somewhere that is bad. Problem is, I have no idea where the connections would be. I went through my manual here but I can't find any mention of where to look. Anyone know?
Thanks
Old May 30, 2003 | 07:13 AM
wwilliam54's Avatar
it WILL run
should be a connector near the driver side rear wheel, it ha a tendency to corrode and not work right (mine didnt read below 1/4 tank)
Old May 30, 2003 | 07:16 AM
TheMoonDog's Avatar
Thanks,
I kind of thought it would be back there because I had to change the fuel pump and that is the same location. Time to jack her up and start wiring!
Old May 30, 2003 | 10:47 AM
fatboy7's Avatar
Got Boost?
theres a good chance the whole connector on the sender unit is corroded, in which case, your hosed cause its a sealed unit, and 'em thangs ain't cheap.
Old May 30, 2003 | 11:42 AM
TheMoonDog's Avatar
Hopefully that's not the case but if it is I have a couple of extra's lying around anyways. May be better off just to replace the whole thing anyways. I'll be able to tell that when I get a peek!
Thanks for mentioning it.
Old May 30, 2003 | 11:46 AM
fatboy7's Avatar
Got Boost?
I sadly know from personal experiance......
Old May 30, 2003 | 03:32 PM
vipernicus42's Avatar
Rotoholic Moderookie
If you've got a fuel level sender for a non-GSL-SE, I'd probably buy it off ya. I need one, badly!
Jon
Old May 30, 2003 | 07:07 PM
justrx8's Avatar
try (http://www.atkinsrotary.com/) i just got a sending from them for about 90.00 dollars that fixed my problem
rgordon1979
40
Mar 15, 2022 12:04 PM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
sherff
Sep 12, 2015 12:22 PM
