new fluids
Old Sep 4, 2001 | 02:46 PM
riffraff's Avatar
smog nazi destroyer
new fluids
i was about to go out and pick up some new fluids for the car, and figured i would check what everyone sugested.. i need everything, engine oil, tranny fluid, clutch, break......
what brands should i look at>? weight?
Old Sep 4, 2001 | 02:56 PM
Pittdp's Avatar
I use Castrol in my engine 10w40, if you have more mile on your engine you may want to go 20w50.
Castrol hydrolic fluid, dot 3
Valvalen gear oil, but am thinking of using Mobil 1.
Old Sep 4, 2001 | 03:13 PM
P.O.S. Racing's Avatar
For what it's worth the POS Racer gets:
Castrol GTX 20w50 in the Engine
Castrol DOT 4 in the Brakes and Clutch Slave
Prestones Dex-Cool in the Radiator 50/50
Synthetics in the Gearbox and Rear end, Haven’t decided on a brand, I’m currently running Valvoline Sythetic blend, but going to change it to full synthetic this weekend. Put 500 Miles on the blend to help clean out the cases before I put the good stuff in it!
Old Sep 4, 2001 | 05:43 PM
MarkPerez's Avatar
Tennis, anyone
I use nothing but valvoline,20-50 ,gear oils,anything dot 4 for
clutch,brakes,and always use prestone,to keep the water pump
bearing,and cooling system slippery.I like straight grades VS multi-
grades but the rotory gets 20-50
Old Sep 4, 2001 | 07:27 PM
cjf's Avatar
cjf
just got some castrol gtx 20w50 oil tonight, got a purolator oil filter (heard they were best), and i am now going to put marvel mystery oil (1 qt.) in with the new oil...and will put some inthe gas too....lubricates everything.. I have the mazda recommended oils in the tranny and rear...may switch to the synthetic soon.. I have been reading up on all this stuff, mostly at the forum , and we have some very knowledgable people out there......good luck......................................cjf..... ................................................
Old Sep 4, 2001 | 09:22 PM
Acuspeed's Avatar
As far as synth oil for the manual trannys, I have used both Redline and Royal Purple. My preference is for the Royal Purple as it made the shifts smoother and, believe it or not, I also noticed a mild increase in fuel milage after switching to it.
Old Sep 4, 2001 | 10:33 PM
Serzy's Avatar
Can Barely Afford Gas :(
I just did an oil change on my car today I put in 4qts of Castrol 20w50 and 1qt Marvels Mystery Oil and I used a Purolator PureOne oil filter for an 85 626... it is the same dimensions except it is about 1" taller than the one they list for the RX-7, cant go wrong with a bigger filter
Old Sep 5, 2001 | 12:32 AM
Pittdp's Avatar
I just did the oil change on my new Protege 5 and it uses the same Mazda oil filter as my Rx-7. Thats odd!!
LongDuck
Oct 7, 2015 08:12 PM
James Knox
Oct 5, 2015 07:56 AM
Frisky Arab
Sep 4, 2015 06:17 PM
