Lightened Flywheel Install
Old May 25, 2003 | 06:23 PM
Jesuscookies's Avatar
I can haz rotary?
I have an 88 TII motor, and I was thinking about putting a lightened steel flywheel on it. The one that I have on there now is currently stock.
If I do this, will I have to remove the front engine cover to replace the counterweight? Is there an eaiser way?
Old May 25, 2003 | 06:24 PM
Resource's Avatar
No, you don't have to replace the counterweight. You just bolt the lightened flywheel right on and go.
Old May 25, 2003 | 06:28 PM
I can haz rotary?
Can you elaborate?
because I thought that If the flywheel was changed the engine would not be balanced, unless I also changed the counterweight?
Old May 25, 2003 | 06:32 PM
Resource's Avatar
Nope, the flywheel is equally balanced.
Old May 25, 2003 | 06:38 PM
I can haz rotary?
Okay, Let me try this question a differnet way:
What causes the engine to be balanced, or unbalanced?
and what does the counterweight accomplish?
Old May 25, 2003 | 06:48 PM
RX-Heven's Avatar
I'll blow it up real good
You will need to purchse a counterweight that attachs to the e-shaft from the rear under the flywheel. The stock flywheels essentially haver their counterweight within them which is one of the reasons they are so heavyCounterweights are generation/engine specific.
The counterweight accomplishes what it is named for.
Old May 28, 2003 | 08:31 AM
Gearhead's Avatar
The counter weight bolts to the E shaft behind the big nut. The lightweight flywheel bolts to the counterweight like a automatic flexplate with 6 bolts. As a matter of fact, the counterweight you'll be using is probably an auto counterweight. This is the set up I'm most familiar with, anyways.
Don.
Old May 29, 2003 | 02:42 AM
Juster's Avatar
I have the racing beat flywheel and boy was it a PITA to install!!
whinin
Mar 30, 2019 07:53 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
