and the dealer said to me
Old May 22, 2003 | 10:23 PM
Narfle's Avatar
Rx7 Wagon
i know i know
dealers are the devil
but i wanted a compression test and some cosmetic things and suspension
nothing on the engine
but i checked the compression test and the mechanic said i have
rotor 1: 7.3 6.8 6.8
rotor 2: 7.5 7.5 6.6
compression
i asked him to heat it up first
it was performed at 258 rpm the dude said that new engines have 12-13 compression on all chambers and mazda requitres a minimum of 8
he also told me there were 4 rear toe links coming to a parts cost of 1331 dollars
tried to charge me for 3 things i didnt ask for
no i thought i heard that anythign a bove 6 was acceptable and anythign above 7 was good on a warm engine
i have the sneaking suspicion this guy is trying to take me for a ride
so for now i said go ahead with two hedlight covers the door handle and the gas door
is my compression fine?
am i right in sa=ying the dealer is trying to take me for a ride?
thx a million
Old May 22, 2003 | 10:37 PM
Wargasm's Avatar
Weird Cat Man
Your compression is just fine, don't sweat that at all. They DO NOT come with 12-13 from Mazda, that is a lie.
Brian
Old May 22, 2003 | 10:56 PM
Narfle's Avatar
Rx7 Wagon
thx man
Old May 22, 2003 | 11:52 PM
duboisr's Avatar
Two toe links ,two trailing links. The trailing links are $150 each .Garfinkle just got them for 3xowner along with the ather bushing she needed. I think the toe bushings can be replaced, the trailing link bushings can not press out .
Old May 23, 2003 | 12:02 AM
Rx-7$4$me's Avatar
That worries me, arent they supposed to be at least within .3-.5??? Cracked seal?
Old May 23, 2003 | 01:05 AM
Narfle's Avatar
Rx7 Wagon
naw if it were a cracked seal wouldnt i get two low numbers?
could be fabricated numbers?
Old May 23, 2003 | 02:02 AM
Sounds like it's time to get a second opinion.
Old May 23, 2003 | 02:35 AM
edscholl's Avatar
busted apex seal will give you low numbers on two faces of the rotor. a bum side seal will give you a low number on 1 face.
Old May 23, 2003 | 03:40 AM
r0t0r-rooter's Avatar
call me Smokie Smokerson
Hell yeah.
Good waste of a trip
Old May 23, 2003 | 07:38 AM
vudoodoodoo's Avatar
Don't pay for what you didn't ask for.
Old May 23, 2003 | 12:23 PM
Wargasm's Avatar
Weird Cat Man
Yeah your numbers aren't all super close together and you do have some variations... which isn't 100% ideal. BUT if the car drives and runs fine, I would not even sweat it at all. Just enjoy the car.
I would not even consider rebuilding that engine unless it has trouble starting or stalls out a lot or something. Those numbers aren't perfect, but they're not what I call "red alert" numbers either.
Drive it and enjoy it
Brian
Old May 23, 2003 | 12:35 PM
Narfle's Avatar
Rx7 Wagon
can do
thx all
Vartok
Sep 24, 2015 02:20 PM
daten
Sep 22, 2015 04:47 PM
