Motor is out, lets discuss my todo list
Old May 21, 2003 | 11:43 AM
93BlackFD's Avatar
built my own engine
Okay, so I've pulled my motor and I have all kinds of time to do things to the engine bay (i sent the motor to pineapple)
Here are things i've come up with:
* Refinish A/C Condensor/Dryer to a polished look, along with all lines going to them
*Respray engine bay
* Remove ignition wiring harness and main engine wiring harness, refinish the wiring harnesses with monster cable for ground points and starter/alternator points, heat shrink the rest back
* Replace the banjo oil line from the front housing to the oil coolers with metric->AN adapters, as well as the oil line to the turbos
* Powdercoat: Engine Lift hooks, UIM, TB, LIM, Waterpump housing, water pump, main pulley, idler pulley, thermostat housing, intake pipes, IC pipes, PS/AC bracket, engine subframe, Alternator, alternator bracket, transmission bell housing
* Polyurethane Motor mounts, DIY kind
* Sheet metal air duct for IC-> Radiator
* Replace all coolant hoses, heater hoses, etc with silicone (any idea on the diameters to order?)
* Remove all solenoids/Sequential systems, plug all nipples on y-pipe, UIM, LIM, and remove the big chunk of metal supporting the airpump bracket off the water pump housing
* Modify exhast manifold for non seq, as well as y-pipe, precontrol, etc
* block off plate, all emissions related items removed, extend the harnesses on the radiator fans
* install 4 cleaned 850CC injectors, new cleaned MOP, new oil injectors, and MOP lines
can anyone think of anything else?
The engine i am ordering is a stage 1 oil mod, street ported 3mm pineapple engine w/ lightened flywheel/pressureplate/some sort of race clutch
Old May 21, 2003 | 11:54 AM
ejmack1's Avatar
Lawn Ornament
hope it starts back up afterwareds
93BlackFD's Avatar
built my own engine
why wouldn't it?
Old May 21, 2003 | 12:08 PM
ejmack1's Avatar
Lawn Ornament
dunno thats what im tryin to figure out on mine, I got rid of my PS and AC installed BOV's on everything uneeded, cut unused connectors out of harness, at the ECU connector. ReSprayed engine bay...
I did alot of the stuff you are wanting to do, no I just can't hold an Idle...
Old May 21, 2003 | 12:18 PM
93BlackFD's Avatar
built my own engine
sounds like you blocked off the idle speed control motor...i did that and you can tune the engine out without it
either that or you forgot to seal one of the block off plates correctly
Old May 21, 2003 | 12:22 PM
dubulup's Avatar
development
Because that's alot to change at once...(Why not go 1300s and 850s, and get a boost controller and get the BnR III's while your at it. get the efini y and mid pipe, also)
Who is going to be tuning this bad boy?
Old May 21, 2003 | 12:25 PM
93BlackFD's Avatar
built my own engine
tim benton will be tuning it, 850cc's are free, and the midpipe is already in my garage
Old May 21, 2003 | 12:27 PM
ejmack1's Avatar
Lawn Ornament
yeah i took the idle speed control motor out, how can I get it runnin right without it?
Old May 21, 2003 | 12:55 PM
93BlackFD's Avatar
built my own engine
adjust the bleed screw (under where the elbow fits onto the TB) with a flathead, it should be screwed all the way in, and then backed out just a tad...
then adjust your primary (single butterfly) throttle screw, it's near where the throttle cable attaches to the throttle assembly, it has an 8mm lock nut, and you back it out to lower idle, and screw it in to raise idle
the bleed screw should control the "bucking" and the other screw controls idle speed
adjust it while the engine is warmed up with the a/c on, and get it to 1000rpms, it should drop to 800 rpms without the a/c on, and should be perfect
Old May 21, 2003 | 01:16 PM
Tim Benton's Avatar
FD title holder since 94
Cool, I was wondering when you were going to get started on that project. How long is Rob going to take with the engine?
Tim
Old May 21, 2003 | 01:26 PM
Marshall's Avatar
Sounds like you got it pretty much worked out Brian. Let me know what you find out about powdercoating shops and prices around here.
Old May 21, 2003 | 01:29 PM
93BlackFD's Avatar
built my own engine
rob said it would take approx 5 weeks, but i might let him keep it longer, as i have to pay to get it back i'm trying to do everything i can while i have the engine out, the ignition harness is coming along nicely, it's sitting in my shower with electramotive all over it removing the electrical goo
i'm removing all unnecessary wires from the wiring harnesses so pinout diagrams and wires are all over my apartment
it should turn out awesome
tim: i'm taking your suggestion on the lightened flywheel/pressure plate and i'm going with a new clutch while i'm at it
marshall: are you still going single? if either if you need any 13B parts, solenoids, etc, i have them all
if either of you want anything powdercoated, let me know, you could probably get a better deal if you get it done w/ all of my parts
batlground can do it, but i'm thinking conyers speedworld as i've seen their results and i'm impressed
Old Jul 9, 2003 | 10:41 PM
93BlackFD's Avatar
built my own engine
Re: Motor is out, lets discuss my todo list
**REMOVED A/C ALL TOGETHER
*Respray engine bay
**DONE
**DONE
**STILL NEED TO PURCHASE BRAIDED
**DONE, ALONG WITH PLENTY MORE
**DONE
**WILL DO AFTER CAR RUNS
**WENT WITH STAINLESS BRAID
**DONE
**DONE
**DONE
**WILL ARRIVE TOMORROW, CLEANED
**WENT WITH LARGE STREET PORT, STAGE 3 OIL, UPGRADED COOLANT, LIGHTWEIGHT FLYWHEEL/STAGE4 CLUTCH
sorry for the caps lock, but it makes it easier to see my progress
Old Jul 9, 2003 | 10:44 PM
93BlackFD's Avatar
built my own engine
oh yeah, and i powdercoated everything myself
marshall, tim: i will charge only cost and you can tip me as needed (gas bill, sweat fees)
Old Jul 9, 2003 | 11:47 PM
pomanferrari's Avatar
*Respray engine bay
Are you independently wealthy or you're unemployed and receiving mental disability payments?
I came up with a similar list but at the rate I'm going, they're going to bury the car with me.
Old Jul 14, 2003 | 03:09 PM
93BlackFD's Avatar
built my own engine
i quit my job to work on my car
i'm down to the point where i'm using my g/f's credit card
Old Jul 14, 2003 | 04:53 PM
tomaszjc7's Avatar
Ahh, the girlfriend's credit card. A beautiful thing.
Old Jul 14, 2003 | 05:12 PM
Tim Benton's Avatar
dude, if you've got the gf's credit card, a single turbo is the way to go Let me know when its a good time to come look at the engine bay, I'd like to see it or better yet, take some pics and post them. Sounds like its coming along nicely.
Tim
Old Jul 14, 2003 | 05:36 PM
jpandes's Avatar
Nice!
Old Jul 14, 2003 | 06:39 PM
GoRacer's Avatar
Speed Mach Go Go Go
Hmm, my engine's out ...does she have a sister?
Old Jul 14, 2003 | 07:09 PM
93BlackFD's Avatar
built my own engine
yeah, just got done grinding the old rubber off the motor mounts and sandblasting them clean, i'm about to powdercoat them gunmetal and assemble with the new urethane
then i'm shipping it off to pineapple, i decided to go with "jason's port" and should have a nice lobe to the idle with a large street port
lightweight flywheel and 6 puck clutch are my next order of business, i have pics before/after of the engine bay progress, i'm searching for some M6x1.00mmx10mm hexhead w/ flange bolts now to reassemble the engine bay accessories
Old Jul 14, 2003 | 07:13 PM
93BlackFD's Avatar
built my own engine
yeah tim, you're welcome to come by anytime and check it out, 404-358-5578 and i'll give ya directions, i need to get that PPF from you sometime anyways
Old Jul 14, 2003 | 09:40 PM
Tim Benton's Avatar
Yeah, I was wondering if you still needed it. Good time to Powder coat it too while its out and before you install it.
Tim
Old Jul 14, 2003 | 10:30 PM
93BlackFD's Avatar
built my own engine
hah! oven is not that big
Old Jul 14, 2003 | 11:00 PM
T88NosRx7's Avatar
wow, thats some todo list, good luck, and keep us posted on how things are coming along.
