Clear plumbers tubing ok for coolant lines?
Old May 20, 2003 | 08:59 PM
Cetchup's Avatar
The Cursed FD
I was thinking about replacing the coolant lines with clear plumbers tubing from like Home depot or something. I havn't been down there to check sizes yet, but I wanted to see if it is safe to use that type of material. Anyone know? I think it would be kinda cool to see the coolant from the filler neck through the hose Maybe I am just an idiot though
Old May 20, 2003 | 10:04 PM
cdk 4219's Avatar
Usually that sort of plastic material will not take the heat too well. After time it may become brittle and hard, while not doing its job that well on your important coolant system.
Old May 20, 2003 | 10:30 PM
c00lduke's Avatar
I've always been a trial and error kinda guy.
I say go for it and let us know.
~Luke
Old May 20, 2003 | 10:33 PM
TYSON's Avatar
WTF is wrong with it now?
No. That stuff is vinyl, I believe, which will not stand the heat and probably won't like the antifreeze either.
Old May 21, 2003 | 12:40 AM
They have heat rating so you can check it.
Old May 21, 2003 | 01:37 AM
rynberg's Avatar
A coolant hose is just about the LAST thing I would experiment on with the FD...just get stock replacements. If you want to drop some coin, get the Therma Flex replacements.
Old May 21, 2003 | 02:16 AM
maxcooper's Avatar
WWFSMD
I would guess that they wouldn't be up to the task, and that they would likely yellow over time (though I'm not sure it would matter much with green coolant in them).
-Max
Old May 21, 2003 | 02:56 AM
skunks's Avatar
I'm a CF and poop smith
remember, unless your using the even's )pressure system, you coolant system is gonna be pressurised as well as being fairly hot. why not use stock ones anyways?
Old May 21, 2003 | 03:33 AM
Wink
Beat me to it again. I was thinking the same thing. Also, remember that the stock coolant hoses are reinforced with an underlying network of cords to lend longevity and strength. I've learned the hard way that in some cases the stock components work better than aftermarket/fabricated pieces.....
rotor_veux
Aug 31, 2015 07:49 PM
