Fuel Injectors
Old May 20, 2003 | 03:29 PM
dpugh's Avatar
Fuel Injectors
I beleive I have dirty fuel injectors on my 83 GSL. What is the cheapest and easiest way to clean them. Would any fuel injector cleaner work.
Thanks
David
Old May 20, 2003 | 03:31 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
83 GSL DOESN'T HAVE FUEL INJECTORS... its carburated... so you might need to rebuild your nikki
Old May 20, 2003 | 03:33 PM
dpugh's Avatar
Nikki
What is a Nikki? Sorry I am a noob!!!
Old May 20, 2003 | 03:43 PM
MRGSL-SE's Avatar
the stock 1st gen carburators are made by NIKKI... why not upgrade your carb to a weber side draft... or a holly 720 cfm carb(j/k 720 is too big)... but NIKKI is your stock carb...
Old May 20, 2003 | 03:55 PM
dpugh's Avatar
$805
Wow That is how much the WEBER 45mm side-draft intake system is!!! Ouch. There has to be something else I can do. I just got the car 2 months ago, and it ran fine before. Any other suggestions would be helpful!!
Another thing that happens is that it sputters at around 4000 rpms. That is why I think it might be the fuel. Don't know???
Old May 20, 2003 | 04:05 PM
Pedestrian X's Avatar
SpAz!
well, start with a bottle of carb cleaner if i were you.
Old May 20, 2003 | 04:36 PM
dpugh's Avatar
RPM Issue
I just went for a drive in it, and couldn't get the RPMS to go over 6000. Strange!! Any suggestions!!
Old May 20, 2003 | 06:51 PM
RotorMotorDriver's Avatar
Seven Is Coming
Change your fuel filter.
~T.J.
Old May 22, 2003 | 08:44 AM
cjf's Avatar
cjf
dpugh, hey fellow "7" owner..I am in winston-salem, nc..I have two 84 gsl-se..I am a "7" nut. If I can help you at all, I would be glad to. I just stopped by a gas station yesterday and looked at this brown gsl this guy had...he was in clemmons..was that you???.. as to yourcar problems,,, need to make sure it is all tuned up...may have a clogger fuel filter...it could be anything related to maintenence... I would havce to know what or what you did not do to the car...then take it step by step and see what we can do to help remedy the problem....let me know if I can help...I am no "expert" but can give you some ideas....cjf
Old May 22, 2003 | 08:52 AM
O 16581 72452 5's Avatar
The infamous number guy!
Old May 22, 2003 | 10:00 AM
cjf's Avatar
cjf
i just pm'ed you ( private message) on the rx7 club...cjf
Old May 22, 2003 | 03:29 PM
dpugh's Avatar
Problems still persist
Well I changed out the fuel filter and had the carborator cleaned. Still nothing. Any other suggestions?
Old May 22, 2003 | 03:34 PM
SpAz!
wow, hmmm.. you cant get it over 6K RPM? is it an auto or 5spd? and when you get up to 6K how is it? does it jsut sorta slow down and slowly get up to 6K the higher u get in the rpm range and then stop at 6K? or what? i lil more info would definelty help out. try a new cap and rotor im thinkin it could be soemthing with your timing or ingition system..
Old May 22, 2003 | 05:52 PM
MRGSL-SE's Avatar
you might have a vacuum leak somewhere...
Old May 22, 2003 | 06:01 PM
SpAz!
do you hear any hissing or anything that may sounds like air escaping from under the hood? does it idle fine?
Old May 22, 2003 | 10:56 PM
dpugh's Avatar
Well I took it over to cjf's house after work. He said it needs a good tune up. The engine was replaced at 114,000 miles back in 1994. It is now at 129,000. The car has been sitting a while. I think it needs a good overhaul. Tonight I replaced the distributer and the rod. Idles better, but still have the same prob at higher rpm's. Tommorow I am going to change the spark plugs and maybe the wires too. Also going to change out the filter and the filter system with the following:
Bönez Air Intake kit
The Bönez Air Intake kit for the 12A replaces the stock air filter lid and air filter for improved flow. We retain the lower portion of the stock air filter housing so that you can continue to use all original hose fittings. This kit is completely bolt on and can be installed with simple hand tools in just a few minutes.
Next will be the oil change and some other routine maintanence. Hopefully that will do the trick.
I got the car like 2 1/2 months ago. It ran very well when I first got it. I have since ragged it out, racing everywhere I go. Maybe I need to take it easy a little.
It is a good thing I have an expert like cjf in my home town. He has two sick GSL-SE VERY Jealous!!!!!!!!
Too answer some questions. It is a 5sp. It skips and sputters when you hit 4000 rpm and then sometimes goes up to 6000 rpm with no power at all.
It idles very well.
I will keep you posted. Thanks for all the help.
Later
David
Old May 22, 2003 | 11:02 PM
Directfreak's Avatar
I am a Jeeper Now.
ignition, prolly trailing.
Old May 24, 2003 | 09:09 AM
dpugh's Avatar
Hey Chris
I did the following after I left your house.
Changed the Distributer Cap and Rotor.
I actually did it myself. Surprise!!! Not to hard.
Friday I took it to a Mechanic. Did the following...
Oil Change
Oil Filter Change
Transmission Fluid Change and Flush
Radiator Flush and Coolant Change
Rear Differential Fluid Change
And they topped off everything else
I am still having huge power loss after 4,000 RPMS
It isn't to bad, but the car struggles up hills sometimes.
Next week I am going to change the intake and filter. also going to change out the spark plugs and wires. Probably will need your help with the spark plugs.
Talk to you later
David
Old May 24, 2003 | 09:39 AM
diabolical1's Avatar
were you mucking around with the carbie recently?
to me, it sounds like you might have disconnected the secondaries ...
Old Jun 5, 2003 | 12:19 AM
dpugh's Avatar
Took it in Today
I took it in to Rotor Sports Racing
http://www.rotorsportsracing.com/
They are going to look at it for me next week. Keep you posted on the status.
Thanks Again for your help
David
Old Jul 26, 2003 | 08:16 AM
dpugh's Avatar
Finally found the problem. The carborator needed to be rebuilt and the catalytic converter needed to be replaced.
I first thought it was a fuel problem, but the catalytic converter was clogged.
If you ever experience some major power loss when you go over 4,000 RPMs, make sure and check the catalytic converter.
Thanks to everyone that helped me with the problem.
Rotorsportsracing.com did all the work. They are the best in the Southeast. My car now hauls ***. Even with the air on and my girlfriend in the car.
They also replaced the spark plug wires and spark plugs. They replaced the converter with a Bonez converter from RX7.com
Later
EfiniGirl
Haltech Forum
Sep 1, 2015 09:31 PM
82streetracer
Aug 23, 2015 09:28 AM
