Solenoids And Vacuum Rack???
Old Sep 3, 2001 | 12:50 AM
swoop's Avatar
I want to clean up my engine. If I remove the solenoids and vacuum rack will I have any problems??? I have an 87 t2 with ACV removed.
Old Sep 3, 2001 | 01:52 AM
Chris Ng's Avatar
I'm with stupid -----^
There are 5 solenoids.. of those 5 you only really need to keep 1 of them.. here's a break down:
EGR Solenoid: If you still have your EGR then keep it connected..If you don't, you can get rid of it.
Twin Scroll Solenoid: Must keep the solenoid unless you removed the twin scroll flapper from the manifold or have it wired open..
Switching solenoid: no ACV? no need for this..
Fuel pressure regulator: you can remove the solenoid as long as you run the vac line from the FPR to a source of vac somewhere else
Relief Solenoid: no ACV? no need for this
There you go.. as you can see.. you don't really need much after you get rid of the acv
Old Sep 3, 2001 | 11:11 AM
swoop's Avatar
THANKS FOR THE HELP
joel(PA)
Oct 4, 2015 06:07 PM
