rear coilovers
Old May 19, 2003 | 04:58 AM
lenh's Avatar
rear coilovers
wondering if anyone is using rear coilovers on a 1st gen i would like to remove spring and add rear coilovers so i can adjust height cant find anyone who carries them, anyone tried installing them on stock shocks with a universal kit
Old May 19, 2003 | 07:56 AM
Maguire's Avatar
Born 2 Brap
Gamble found this a while ago and posted the link:
http://www.carrerashocks.com/CoilOverKitPage.htm
I dont know of anyone that has tried it out yet.
Old May 19, 2003 | 08:30 AM
Gregs's Avatar
so if that kit was installed on an fb would the coils on the rearend be completley removed?...
-greg
Old May 19, 2003 | 09:48 AM
The stock shock mounting location on the 1st gen can not support the weight of the car thats why the spring location on the 1st gen body is so "Beefy" cause it actually supports the weight of the car. I built the front coil over setup on the front of my car and have almost finished the rear setup but they will be short and the coilover setup will be located where the stock spring is.
It will work awsome on the track but may not have the desired suspension travel wanted for the street.
That is somthing I am addressing at the moment by changing the mounting location on the rear end axle tubes.
Old May 19, 2003 | 12:35 PM
gamble302's Avatar
roadkill hats rock
yeah youd have to beef up the mounting location for it to work. my suspension holds the car up at the moment, so my money is going towards turbo swap at the moment
Old May 19, 2003 | 03:00 PM
onepointone's Avatar
i say what i want
Old May 19, 2003 | 05:25 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
Rear Spring Adjusters
$45.00/ea
150lb or 125lb Rear Springs
$48.00/ea
http://iscracing.net/suspension_1.htm
Have them on my 1st gen. WORK GREAT.
Old May 19, 2003 | 06:58 PM
DriveFast7 thanx for the heads up thats a nice website.
But I did not see any 1st gen rear coilover kits.
Thats what were looking for not just a hieght adj. spring
A coilover kit will have the shock in the spring like the front.
They have some good parts though. Thanx again.
Old May 19, 2003 | 09:25 PM
Hyper4mance2k's Avatar
The Shadetree Project
schwed another thing for me to buy!!
Old May 20, 2003 | 07:48 AM
Maguire's Avatar
Born 2 Brap
$45.00/ea
$48.00/ea
wow, thats looks awesome! you should add that to the vendors sticky.
Old Oct 24, 2006 | 03:23 PM
luiml73's Avatar
Rotary Powered Boobies
$45.00/ea
$48.00/ea
Just ordered mine with the 125lb springs. They have them in stock. Next are the Illuminas.
Old Oct 24, 2006 | 03:46 PM
13BT_RX3's Avatar
The General RE
I have heard of people adapting Foxbody Mustang rear coilover kits on FBs.
Old Nov 18, 2006 | 02:47 PM
luiml73's Avatar
$45.00/ea
$48.00/ea
I tried to install mine yesterday and it did'nt work. Even at the highest setting it lowered the car 2" and it rubbed. I'm sending my wheels to ccw on monday to have the outer lip changed from 6" to 4". I'll be left with a 10" inch wheel instead of 12" but the 315's will still fit.
I should now be able to lower the rear at least 3" so it looks like this.
I'll post pics by Sat of the install and final results.
Old Nov 18, 2006 | 02:52 PM
aussiesmg's Avatar
Thunder from downunder
My rear coil over project is moving slowly but it can be done, you need to weld though....
Old Nov 18, 2006 | 04:23 PM
Luiml you should've gotten you springs from Gforce and the adjusters from ISC. G force modifies their eibach springs to fit better.
Old Nov 18, 2006 | 04:50 PM
luiml73's Avatar
Damn!! too late now. I'll see how everything goes on Friday.
Old Nov 20, 2006 | 04:35 AM
Maguire's Avatar
Born 2 Brap
whoa, thread from the dead.
Old Feb 22, 2007 | 12:13 AM
glosoli's Avatar
Didn't want to start a new thread.
Anyone have some info on the ISC rear adjusters? What spring they work and don't work with?
I'm pretty much stomped on this subject.
thanks in advance.
Old Feb 22, 2007 | 12:23 AM
Zyrano's Avatar
The springs you get from isc will work, but I know the springs from eibach will not work, the spring id is too small. not sure about other springs.
Old Feb 22, 2007 | 01:15 AM
blacknmild874's Avatar
DriveFast7 do you have pics of them installed and the ride height they gave you? i'd love to see some pics of these installed.
Old Feb 22, 2007 | 09:02 AM
rotaryB-2000's Avatar
Psalms 37**25
I am working on my 79 as week speak.
I am installing strange coilovers where the oem shocks are located. i may have to strengthen the factory bracket. Oh and i am running a toyota 4x4 rear end with 2nd gen 4bolt disk and calipers. I will post pics..
Old Feb 22, 2007 | 01:54 PM
HadaGSL-SE's Avatar
1st gens only
The ISC Racing adjusters also do not fit Racing Beat Springs.
I just installed mine and had to order springs from ISC as well after I found out the Racing Beat springs I had on the car didn't work.
No comment on ride since it hasnt been driven yet. But the quality of the parts, customer service and shipping time from ISC Racing is really good. Just give them a call.
-Greg
Old Feb 22, 2007 | 06:56 PM
glosoli's Avatar
I'd love to see that when done.
Old Feb 24, 2007 | 06:54 PM
slowautoxr's Avatar
autoxr/rallyxr
I use the ISC rear spring adjusters and their rear springs to RAISE my car for rallyx. For street duty, I can turn them all the way down or simply remove them.
Old Feb 25, 2007 | 07:05 PM
DriveFast7's Avatar
best pics i could find
http://rides.webshots.com/photo/1132...33406361RZeBwS
http://rides.webshots.com/photo/1037...33406361jAVmJe
there is some more thread on the adjuster to go higher. don't remember how much.
if higher is needed u can get poly spring seats to put on top of the adjuster. from energy suspension.
