How much torque does the flywheel need?
Old May 17, 2003 | 10:15 PM
JIMMY54's Avatar
GSL-SE PRO
Quick question, Im installing my lightweight flywheel and i can't find my manual, Do any of you guys happen to know how much I should torque it down?
Also my Pressure plate has some heat spots (discolored), Is that somthing i should really worry about? The clutch is still good.
Old May 17, 2003 | 11:58 PM
MarkPerez's Avatar
Tennis, anyone
No big deal on the presure plate, if the disk is shinny
or glazed looking and discoloured, then worry. the torque spec's for flywheel :... i'm unclear if the lbs. are for all flywheels, ie, steel / alloy . 289 - 362 lbs.
clutch cover 13 - 20 lbs.
Old May 18, 2003 | 03:48 AM
Ultralights's Avatar
maybee this might help
http://www.iluvmyrx7.com/1stgen/manu...CAL%20DATA.pdf
Old May 19, 2003 | 03:34 AM
karism's Avatar
Adolf Hitler Verfechter
The setting is 289-362 ft/lb
or 400-500nm.
LongDuck
Oct 7, 2015 08:12 PM
