Microtech Datalog from my drive into work (WITH A PROBLEM) - 1-399
Old May 16, 2003 | 07:56 AM
Josepi's Avatar
Despise Enmity
Ok, I'm going to post it all just so you guys can critique the whole thing..
Hesitation around 80-160...only in one spot that I can't pinpoint.
Here goes:
MicroTech DATA Logger 07:46:04 am Friday, May 16, 2003
LOG RPM LOAD T.P.S. Timing Output Water Air Battery AFR Aux 1 Aux 2 Status Errors
# 1 2620 -27 Hg 00% 10° 2.86sT 92°c 35°c 12.75v 14.7 . . IDLE . '
# 2 2560 -27 Hg 00% 10° 2.86sT 92°c 35°c 12.82v 14.7 . . IDLE . '
# 3 2500 -27 Hg 00% 10° 2.86sT 92°c 35°c 12.88v 14.7 . . IDLE . '
# 4 2440 -27 Hg 00% 10° 2.86sT 92°c 35°c 13.12v 14.7 . . IDLE . '
# 5 2380 -27 Hg 00% 10° 2.86sT 92°c 35°c 13.06v 14.7 . . IDLE . '
# 6 2380 -27 Hg 03% 25° 2.57sT 92°c 35°c 13.06v 14.7 . . . . '
# 7 2320 -25 Hg 45% 24° 2.57sT 92°c 35°c 13.06v 14.7 . . . . '
# 8 2250 -22 Hg 52% 24° 2.57sT 92°c 35°c 13.00v 14.4 . . . . '
# 9 2320 -20 Hg 76% 25° 2.57sT 92°c 35°c 13.00v 12.7 . . RPMcrs . '
# 10 2250 -19 Hg 78% 25° 2.86sT 92°c 35°c 12.95v 13.3 . . RPMcrs . '
# 11 2320 -19 Hg 80% 25° 2.86sT 92°c 34°c 12.95v 13.6 . . . . '
# 12 2320 -17 Hg 85% 25° 3.05sT 92°c 34°c 12.95v 13.5 . . . . '
# 13 2320 -16 Hg 89% 25° 3.14sT 92°c 34°c 12.95v 13.6 . . . . '
# 14 2320 -14 Hg 99% 25° 3.62sT 92°c 34°c 12.95v 13.8 . . . . '
# 15 2380 -12 Hg 99% 26° 4.19sT 92°c 33°c 12.95v 14.7 . . . . '
# 16 2440 -10 Hg 99% 25° 4.43sT 92°c 33°c 12.88v 14.7 . . . . '
# 17 2440 -10 Hg 99% 25° 4.43sT 92°c 32°c 12.88v 13.8 . . . . '
# 18 2500 -09 Hg 99% 27° 5.00sT 92°c 32°c 12.88v 13.3 . . . . '
# 19 2560 -05 Hg 99% 25° 5.86sT 92°c 32°c 12.88v 13.1 . . . . '
# 20 2620 -04 Hg 99% 25° 6.19sT 92°c 31°c 12.88v 13.2 . . RPMwot . '
# 21 2750 -00 Hg 99% 25° 7.19sT 92°c 31°c 12.82v 13.3 . . RPMwot . '
# 22 2880 -00 Hg 99% 25° 7.19sT 92°c 31°c 12.82v 13.7 . . RPMwot . '
# 23 2950 +00 Hg 99% 25° 7.19sT 92°c 31°c 12.82v 14.7 . . RPMwot . '
# 24 3060 +00 Hg 99% 25° 4.81mS 92°c 31°c 12.82v 14.7 . . RPMwot . '
# 25 3180 +02psi 99% 25° 5.76mS 92°c 31°c 12.75v 14.7 . . RPMwot . '
# 26 3380 +02psi 99% 25° 5.81mS 92°c 31°c 12.75v 13.3 . . RPMwot . '
# 27 3440 +04psi 99% 25° 6.10mS 92°c 31°c 12.75v 13.2 . . RPMwot . '
# 28 3560 +02psi 99% 25° 5.67mS 92°c 31°c 12.75v 13.2 . . RPMwot . '
# 29 3750 +02psi 99% 25° 5.62mS 92°c 31°c 12.82v 13.3 . . RPMwot . '
# 30 3820 +04psi 99% 25° 6.48mS 92°c 31°c 13.00v 13.1 . . RPMwot . '
# 31 4060 +04psi 99% 25° 6.48mS 92°c 31°c 12.95v 13.0 . . RPMwot . '
# 32 4120 +03psi 99% 25° 5.95mS 92°c 31°c 12.88v 13.0 . . RPMwot . '
# 33 4320 +03psi 99% 25° 5.86mS 92°c 31°c 12.88v 13.0 . . RPMwot . '
# 34 4440 +02psi 99% 25° 5.71mS 92°c 31°c 12.82v 13.1 . . RPMwot . '
# 35 4620 +02psi 99% 25° 5.67mS 92°c 31°c 12.82v 13.1 . . RPMwot . '
# 36 4750 +03psi 99% 25° 6.00mS 92°c 31°c 12.82v 13.2 . . RPMwot . '
# 37 4950 +02psi 99% 25° 5.76mS 92°c 31°c 12.82v 13.2 . . RPMwot . '
# 38 5060 +05psi 99% 25° 6.62mS 92°c 31°c 12.82v 13.2 . . RPMwot . '
# 39 5180 +03psi 99% 25° 6.05mS 92°c 31°c 12.82v 13.3 . . RPMwot . '
# 40 5500 +04psi 99% 25° 6.33mS 92°c 32°c 12.82v 13.5 . . RPMwot . '
# 41 5620 +03psi 99% 25° 5.90mS 92°c 32°c 13.06v 13.8 . . RPMwot . '
# 42 6180 -21 Hg 32% 27° 2.57sT 92°c 32°c 13.32v 13.2 . . . . '
# 43 5750 -27 Hg 03% 27° 2.57sT 92°c 32°c 13.38v 14.7 . . . . '
# 44 5320 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.38v 14.7 . . IDLE . '
# 45 4880 -27 Hg 00% 10° 2.86sT 90°c 32°c 13.44v 14.7 . . IDLE . '
# 46 4620 -27 Hg 00% 10° 2.86sT 90°c 32°c 13.44v 14.7 . . IDLE . '
# 47 3750 -27 Hg 00% 10° 2.86sT 90°c 32°c 13.44v 14.7 . . IDLE . '
# 48 3750 -27 Hg 00% 10° 2.86sT 90°c 32°c 13.44v 14.7 . . IDLE . '
# 49 3820 -27 Hg 00% 10° 2.86sT 90°c 32°c 13.44v 14.7 . . IDLE . '
# 50 3750 -27 Hg 00% 10° 2.86sT 90°c 32°c 13.44v 14.7 . . IDLE . '
# 51 3750 -27 Hg 00% 10° 2.86sT 90°c 33°c 13.44v 14.7 . . IDLE . '
# 52 3750 -27 Hg 00% 10° 2.86sT 90°c 33°c 13.44v 14.7 . . IDLE . '
# 53 3750 -27 Hg 00% 10° 2.86sT 90°c 33°c 13.44v 14.7 . . IDLE . '
# 54 3680 -27 Hg 00% 10° 2.86sT 90°c 33°c 13.44v 14.7 . . IDLE . '
# 55 3680 -27 Hg 00% 10° 2.86sT 90°c 33°c 13.44v 14.7 . . IDLE . '
# 56 3680 -27 Hg 00% 10° 2.86sT 90°c 33°c 13.44v 14.7 . . IDLE . '
# 57 3560 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 58 3560 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 59 3560 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 60 3560 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 61 3500 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 62 3440 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 63 3440 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 64 3440 -27 Hg 00% 10° 2.86sT 90°c 34°c 13.44v 14.7 . . IDLE . '
# 65 3380 -27 Hg 00% 10° 2.86sT 90°c 35°c 13.44v 14.7 . . IDLE . '
# 66 3440 -27 Hg 00% 10° 2.86sT 92°c 35°c 13.44v 14.7 . . IDLE . '
# 67 3380 -27 Hg 00% 10° 2.86sT 90°c 35°c 13.44v 14.7 . . IDLE . '
# 68 3380 -27 Hg 18% 27° 2.57sT 90°c 35°c 13.44v 14.7 . . . . '
# 69 3380 -21 Hg 99% 28° 2.57sT 90°c 35°c 13.44v 14.7 . . RPMcrs . '
# 70 3320 -16 Hg 99% 28° 3.29sT 90°c 34°c 13.44v 12.5 . . . . '
# 71 3320 -14 Hg 99% 28° 3.62sT 90°c 34°c 13.44v 13.0 . . . . '
# 72 3380 -14 Hg 99% 28° 3.62sT 90°c 34°c 13.44v 13.0 . . . . '
# 73 3380 -13 Hg 99% 28° 4.00sT 92°c 33°c 13.44v 12.9 . . . . '
# 74 3440 -10 Hg 99% 27° 4.33sT 90°c 33°c 13.44v 12.9 . . . . '
# 75 3440 -09 Hg 99% 27° 5.00sT 92°c 33°c 13.25v 13.7 . . . . '
# 76 3500 -04 Hg 99% 27° 6.19sT 92°c 32°c 13.32v 13.8 . . RPMwot . '
# 77 3560 -03 Hg 99% 25° 4.33mS 92°c 32°c 13.38v 14.7 . . RPMwot . '
# 78 3560 -00 Hg 99% 25° 4.81mS 92°c 32°c 13.25v 13.3 . . RPMwot . '
# 79 3680 +02psi 99% 25° 5.62mS 92°c 32°c 13.32v 13.3 . . RPMwot . '
# 80 3750 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.0 . . RPMwot . '
# 81 3820 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.1 . . RPMwot . '
# 82 3880 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.0 . . RPMwot . '
# 83 3880 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 12.9 . . Pump2 M . '
# 84 4000 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 12.7 . . RPMwot . '
# 85 4120 -02 Hg 99% 30° 6.00mS 92°c 31°c 13.32v 12.7 . . Pump2 M . '
# 86 4120 -02 Hg 99% 25° 4.71mS 92°c 31°c 13.32v 12.3 . . Pump2 M . '
# 87 4120 -02 Hg 99% 25° 4.71mS 92°c 31°c 13.32v 12.4 . . RPMwot . '
# 88 4180 -02 Hg 99% 27° 4.57mS 92°c 31°c 13.32v 12.3 . . RPMwot . '
# 89 4180 -04 Hg 99% 25° 6.33mS 92°c 31°c 13.32v 12.3 . . RPMwot . '
# 90 4380 -08 Hg 99% 27° 5.05sT 92°c 31°c 13.38v 12.4 . . Pump2 M . '
# 91 4380 -13 Hg 99% 27° 3.90sT 92°c 31°c 13.38v 12.1 . . . . '
# 92 4320 -10 Hg 99% 27° 4.33sT 92°c 31°c 13.38v 12.4 . . . . '
# 93 4320 -12 Hg 99% 28° 4.14sT 92°c 31°c 13.38v 12.4 . . . . '
# 94 4380 -12 Hg 99% 28° 4.14sT 92°c 31°c 13.38v 12.7 . . . . '
# 95 4380 -16 Hg 99% 28° 3.29sT 92°c 31°c 13.38v 12.5 . . . . '
# 96 4380 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.38v 12.5 . . . . '
# 97 4320 -17 Hg 99% 28° 2.90sT 92°c 32°c 13.38v 12.7 . . . . '
# 98 4320 -26 Hg 18% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 99 4250 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 100 4250 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 101 4250 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 102 4250 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 103 4250 -27 Hg 09% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 104 4180 -26 Hg 57% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 105 4120 -22 Hg 99% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 106 4250 -17 Hg 99% 28° 3.00sT 92°c 32°c 13.44v 12.7 . . . . '
# 107 4180 -19 Hg 99% 28° 2.86sT 92°c 32°c 13.44v 12.7 . . . . '
# 108 4180 -16 Hg 99% 28° 3.14sT 92°c 32°c 13.44v 12.8 . . . . '
# 109 4180 -15 Hg 99% 28° 3.43sT 92°c 32°c 13.44v 12.8 . . . . '
# 110 4180 -16 Hg 99% 28° 3.14sT 92°c 32°c 13.44v 12.8 . . . . '
# 111 4180 -19 Hg 99% 28° 2.86sT 92°c 32°c 13.44v 12.8 . . . . '
# 112 4180 -15 Hg 99% 28° 3.43sT 92°c 32°c 13.38v 12.9 . . . . '
# 113 4320 -09 Hg 99% 27° 4.76sT 92°c 32°c 13.38v 13.4 . . . . '
# 114 4320 -08 Hg 99% 27° 5.14sT 92°c 32°c 13.38v 13.4 . . . . '
# 115 4250 -07 Hg 99% 27° 5.43sT 92°c 32°c 13.38v 13.2 . . . . '
# 116 4320 -09 Hg 99% 27° 4.76sT 92°c 32°c 13.38v 13.2 . . . . '
# 117 4380 -05 Hg 99% 27° 5.90sT 92°c 32°c 13.38v 13.3 . . RPMwot . '
# 118 4320 -15 Hg 99% 28° 3.33sT 92°c 32°c 13.38v 12.7 . . . . '
# 119 3820 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 120 3560 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 121 3320 -26 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 122 3060 -27 Hg 00% 10° 2.86sT 92°c 32°c 13.44v 14.7 . . IDLE . '
# 123 3120 -27 Hg 07% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 124 3120 -25 Hg 36% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 125 3120 -23 Hg 52% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 126 3120 -23 Hg 67% 27° 2.57sT 92°c 32°c 13.44v 14.7 . . . . '
# 127 3060 -21 Hg 78% 27° 2.57sT 92°c 33°c 13.44v 12.9 . . . . '
# 128 3120 -20 Hg 96% 27° 2.71sT 92°c 33°c 13.44v 12.1 . . RPMcrs . '
# 129 3120 -19 Hg 99% 28° 2.76sT 92°c 32°c 13.44v 12.8 . . RPMcrs . '
# 130 3120 -17 Hg 99% 28° 3.00sT 92°c 32°c 13.44v 13.0 . . . . '
# 131 3120 -19 Hg 99% 28° 2.71sT 92°c 32°c 13.44v 13.2 . . . . '
# 132 3120 -19 Hg 97% 28° 2.71sT 92°c 32°c 13.44v 13.0 . . RPMcrs . '
# 133 3120 -19 Hg 96% 28° 2.71sT 92°c 32°c 13.44v 12.8 . . RPMcrs . '
# 134 3120 -19 Hg 96% 28° 2.86sT 92°c 32°c 13.44v 12.9 . . RPMcrs . '
# 135 3120 -19 Hg 99% 28° 2.86sT 92°c 32°c 13.44v 12.9 . . . . '
# 136 3120 -15 Hg 99% 28° 3.43sT 92°c 32°c 13.44v 13.4 . . . . '
# 137 3120 -15 Hg 99% 28° 3.33sT 92°c 32°c 13.44v 14.0 . . . . '
# 138 3120 -12 Hg 99% 28° 4.05sT 92°c 32°c 13.44v 13.8 . . . . '
# 139 3120 -12 Hg 99% 28° 4.29sT 92°c 32°c 13.44v 13.5 . . . . '
# 140 3120 -12 Hg 99% 28° 4.29sT 92°c 32°c 13.44v 13.6 . . . . '
# 141 3180 -14 Hg 99% 28° 3.71sT 92°c 32°c 13.44v 13.5 . . . . '
# 142 3180 -14 Hg 99% 28° 3.76sT 92°c 32°c 13.44v 13.4 . . . . '
# 143 3180 -14 Hg 99% 28° 3.62sT 92°c 32°c 13.44v 13.5 . . . . '
# 144 3180 -14 Hg 99% 28° 3.62sT 92°c 32°c 13.44v 13.4 . . . . '
# 145 3180 -15 Hg 99% 28° 3.48sT 92°c 32°c 13.44v 13.6 . . . . '
# 146 3180 -16 Hg 99% 28° 3.29sT 92°c 32°c 13.44v 13.5 . . . . '
# 147 3180 -14 Hg 99% 28° 3.76sT 92°c 32°c 13.44v 13.5 . . . . '
# 148 3250 -15 Hg 99% 28° 3.33sT 92°c 32°c 13.44v 13.5 . . . . '
# 149 3250 -14 Hg 99% 28° 3.76sT 92°c 32°c 13.44v 13.4 . . . . '
# 150 3180 -15 Hg 99% 28° 3.48sT 92°c 32°c 13.44v 13.6 . . . . '
# 151 3180 -14 Hg 99% 28° 3.71sT 92°c 32°c 13.44v 13.4 . . . . '
# 152 3250 -14 Hg 99% 28° 3.62sT 92°c 31°c 13.44v 13.5 . . . . '
# 153 3250 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.5 . . . . '
# 154 3250 -14 Hg 99% 28° 3.71sT 92°c 31°c 13.44v 13.5 . . . . '
# 155 3250 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.4 . . . . '
# 156 3250 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.4 . . . . '
# 157 3250 -14 Hg 99% 28° 3.71sT 92°c 31°c 13.44v 13.4 . . . . '
# 158 3250 -14 Hg 99% 28° 3.71sT 92°c 31°c 13.44v 13.4 . . . . '
# 159 3250 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.4 . . . . '
# 160 3250 -14 Hg 99% 28° 3.57sT 92°c 31°c 13.44v 13.4 . . . . '
# 161 3250 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.4 . . . . '
# 162 3250 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.3 . . . . '
# 163 3250 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.5 . . . . '
# 164 3250 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.5 . . . . '
# 165 3320 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.4 . . . . '
# 166 3320 -12 Hg 99% 28° 4.05sT 92°c 31°c 13.44v 13.5 . . . . '
# 167 3250 -10 Hg 99% 27° 4.33sT 92°c 31°c 13.44v 13.5 . . . . '
# 168 3320 -10 Hg 99% 27° 4.57sT 92°c 31°c 13.38v 13.6 . . . . '
# 169 3250 -10 Hg 99% 27° 4.48sT 92°c 31°c 13.38v 13.6 . . . . '
# 170 3320 -07 Hg 99% 27° 5.57sT 92°c 31°c 13.38v 13.5 . . . . '
# 171 3320 -05 Hg 99% 25° 5.90sT 92°c 31°c 13.38v 13.4 . . . . '
# 172 3320 -08 Hg 99% 27° 5.14sT 92°c 31°c 13.38v 13.2 . . . . '
# 173 3320 -10 Hg 99% 27° 4.48sT 92°c 31°c 13.38v 13.2 . . . . '
# 174 3380 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.38v 13.1 . . . . '
# 175 3380 -14 Hg 99% 28° 3.57sT 92°c 31°c 13.44v 13.3 . . . . '
# 176 3380 -15 Hg 99% 28° 3.48sT 92°c 31°c 13.44v 13.4 . . . . '
# 177 3380 -14 Hg 99% 28° 3.57sT 92°c 31°c 13.44v 13.3 . . . . '
# 178 3380 -15 Hg 99% 28° 3.48sT 92°c 31°c 13.44v 13.4 . . . . '
# 179 3320 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.2 . . . . '
# 180 3380 -16 Hg 99% 28° 3.14sT 92°c 31°c 13.44v 13.2 . . . . '
# 181 3380 -17 Hg 99% 28° 3.05sT 92°c 31°c 13.44v 13.1 . . . . '
# 182 3380 -17 Hg 99% 28° 3.05sT 92°c 31°c 13.44v 13.2 . . . . '
# 183 3380 -17 Hg 99% 28° 3.00sT 92°c 31°c 13.44v 13.0 . . . . '
# 184 3320 -17 Hg 99% 28° 3.00sT 92°c 31°c 13.44v 13.0 . . . . '
# 185 3380 -17 Hg 99% 28° 3.00sT 92°c 31°c 13.44v 13.0 . . RPMcrs . '
# 186 3320 -17 Hg 99% 28° 2.90sT 92°c 31°c 13.44v 13.0 . . . . '
# 187 3380 -17 Hg 99% 28° 3.00sT 92°c 31°c 13.44v 13.1 . . . . '
# 188 3320 -16 Hg 99% 28° 3.14sT 92°c 31°c 13.44v 13.1 . . . . '
# 189 3320 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 13.5 . . . . '
# 190 3320 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 13.7 . . . . '
# 191 3320 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 13.6 . . . . '
# 192 3380 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.5 . . . . '
# 193 3320 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.5 . . . . '
# 194 3320 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 13.5 . . . . '
# 195 3320 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.4 . . . . '
# 196 3380 -14 Hg 99% 28° 3.71sT 92°c 31°c 13.44v 13.4 . . . . '
# 197 3380 -14 Hg 99% 28° 3.57sT 92°c 31°c 13.44v 13.4 . . . . '
# 198 3380 -14 Hg 99% 28° 3.71sT 92°c 31°c 13.44v 13.4 . . . . '
# 199 3320 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.5 . . . . '
# 200 3380 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.4 . . . . '
# 201 3380 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.5 . . . . '
# 202 3320 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.4 . . . . '
# 203 3380 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.4 . . . . '
# 204 3380 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.4 . . . . '
# 205 3380 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.4 . . . . '
# 206 3380 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.4 . . . . '
# 207 3380 -14 Hg 99% 28° 3.76sT 92°c 31°c 13.44v 13.5 . . . . '
# 208 3380 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.44v 13.4 . . . . '
# 209 3380 -12 Hg 99% 28° 4.14sT 92°c 31°c 13.44v 13.4 . . . . '
# 210 3440 -13 Hg 99% 28° 3.90sT 92°c 31°c 13.38v 13.5 . . . . '
# 211 3440 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.38v 13.7 . . . . '
# 212 3380 -12 Hg 99% 27° 4.05sT 92°c 31°c 13.38v 13.6 . . . . '
# 213 3440 -09 Hg 99% 28° 4.71sT 92°c 31°c 13.38v 13.7 . . . . '
# 214 3440 -09 Hg 99% 27° 4.76sT 92°c 31°c 13.38v 13.6 . . . . '
# 215 3440 -10 Hg 99% 27° 4.33sT 92°c 31°c 13.38v 13.6 . . . . '
# 216 3440 -08 Hg 99% 27° 5.14sT 92°c 31°c 13.38v 13.5 . . . . '
# 217 3500 -08 Hg 99% 27° 5.33sT 92°c 31°c 13.38v 13.5 . . . . '
# 218 3500 -05 Hg 99% 25° 6.00sT 92°c 31°c 13.38v 13.3 . . RPMwot . '
# 219 3500 -07 Hg 99% 27° 5.43sT 92°c 31°c 13.38v 13.3 . . . . '
# 220 3560 -03 Hg 99% 27° 4.33mS 92°c 31°c 13.38v 14.4 . . RPMwot . '
# 221 3560 -04 Hg 99% 25° 4.24mS 92°c 31°c 13.18v 13.5 . . RPMwot . '
# 222 3560 -02 Hg 99% 25° 4.67mS 92°c 31°c 13.25v 13.4 . . RPMwot . '
# 223 3560 -00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.1 . . RPMwot . '
# 224 3620 -00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.1 . . RPMwot . '
# 225 3620 -00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.1 . . RPMwot . '
# 226 3680 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.1 . . RPMwot . '
# 227 3680 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.1 . . RPMwot . '
# 228 3750 +00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.2 . . RPMwot . '
# 229 3820 -00 Hg 99% 25° 4.81mS 94°c 31°c 13.32v 13.2 . . RPMwot . '
# 230 3820 +02psi 99% 25° 5.67mS 94°c 31°c 13.32v 13.1 . . RPMwot . '
# 231 3820 -02 Hg 99% 25° 4.62mS 92°c 31°c 13.32v 13.0 . . RPMwot . '
# 232 3820 -00 Hg 99% 25° 4.81mS 92°c 31°c 13.32v 13.0 . . RPMwot . '
# 233 3880 -09 Hg 99% 27° 4.76sT 92°c 31°c 13.38v 12.4 . . . . '
# 234 3880 -09 Hg 99% 27° 4.71sT 92°c 31°c 13.38v 12.0 . . . . '
# 235 3950 -09 Hg 99% 27° 4.71sT 92°c 31°c 13.38v 12.1 . . . . '
# 236 3950 -13 Hg 99% 28° 4.00sT 92°c 31°c 13.38v 12.3 . . . . '
# 237 3950 -13 Hg 99% 28° 3.86sT 92°c 31°c 13.38v 12.4 . . . . '
# 238 3950 -15 Hg 99% 28° 3.48sT 92°c 31°c 13.38v 12.5 . . . . '
# 239 3950 -12 Hg 99% 28° 4.05sT 92°c 31°c 13.38v 12.7 . . . . '
# 240 3950 -14 Hg 99% 28° 3.71sT 92°c 31°c 13.38v 12.8 . . . . '
# 241 3950 -15 Hg 99% 28° 3.48sT 92°c 31°c 13.44v 12.8 . . . . '
# 242 3950 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 12.9 . . . . '
# 243 3950 -16 Hg 99% 28° 3.14sT 92°c 31°c 13.44v 12.9 . . . . '
# 244 3950 -17 Hg 99% 28° 3.05sT 92°c 31°c 13.44v 12.9 . . . . '
# 245 3950 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.0 . . . . '
# 246 3880 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.0 . . . . '
# 247 4000 -14 Hg 99% 28° 3.57sT 92°c 31°c 13.44v 13.0 . . . . '
# 248 3950 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 13.1 . . . . '
# 249 4000 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 13.1 . . . . '
# 250 3950 -13 Hg 99% 28° 4.00sT 92°c 31°c 13.38v 13.1 . . . . '
# 251 4000 -10 Hg 99% 27° 4.43sT 92°c 31°c 13.38v 13.3 . . . . '
# 252 3950 -10 Hg 99% 30° 5.57sT 92°c 31°c 13.38v 13.1 . . Pump2 M . '
# 253 3950 -09 Hg 99% 30° 6.14sT 94°c 31°c 13.38v 12.7 . . Pump2 M . '
# 254 4000 -07 Hg 99% 30° 7.05sT 94°c 31°c 13.38v 12.7 . . Pump2 M . '
# 255 4000 -05 Hg 99% 25° 6.05sT 92°c 31°c 13.38v 12.9 . . Pump2 M . '
# 256 4000 -05 Hg 99% 27° 4.00sT 94°c 31°c 13.38v 13.3 . . . . '
# 257 4000 -04 Hg 99% 25° 6.43sT 92°c 31°c 13.38v 13.0 . . RPMwot . '
# 258 4060 -05 Hg 99% 30° 7.43sT 94°c 31°c 13.38v 13.0 . . Pump2 M . '
# 259 4060 -08 Hg 99% 27° 5.05sT 92°c 31°c 13.38v 12.8 . . Pump2 M . '
# 260 4060 -09 Hg 99% 28° 4.86sT 92°c 31°c 13.38v 13.2 . . . . '
# 261 4060 -10 Hg 99% 27° 4.33sT 92°c 31°c 13.38v 13.3 . . . . '
# 262 4000 -13 Hg 99% 27° 3.86sT 92°c 31°c 13.38v 13.2 . . . . '
# 263 4120 -12 Hg 99% 28° 4.05sT 92°c 31°c 13.38v 13.3 . . . . '
# 264 4000 -13 Hg 99% 28° 3.90sT 92°c 31°c 13.38v 13.3 . . . . '
# 265 4060 -14 Hg 99% 28° 3.57sT 92°c 31°c 13.38v 13.2 . . . . '
# 266 4000 -15 Hg 99% 28° 3.43sT 92°c 31°c 13.44v 13.2 . . . . '
# 267 4000 -15 Hg 99% 28° 3.48sT 94°c 31°c 13.38v 13.2 . . . . '
# 268 4000 -15 Hg 99% 28° 3.33sT 92°c 31°c 13.44v 13.3 . . . . '
# 269 4000 -15 Hg 99% 28° 3.48sT 92°c 31°c 13.32v 13.5 . . . . '
# 270 4060 -13 Hg 99% 27° 4.00sT 94°c 31°c 13.25v 14.4 . . . . '
# 271 4000 -05 Hg 99% 30° 7.43sT 94°c 31°c 13.32v 13.6 . . Pump2 M . '
# 272 4060 -00 Hg 99% 25° 4.81mS 94°c 31°c 13.25v 13.7 . . Pump2 M . '
# 273 4060 +00 Hg 99% 25° 4.81mS 94°c 31°c 13.18v 13.8 . . RPMwot . '
# 274 4120 -00 Hg 99% 25° 4.81mS 94°c 31°c 13.32v 13.6 . . RPMwot . '
# 275 4120 -08 Hg 99% 27° 5.29sT 94°c 31°c 13.32v 13.0 . . . . '
# 276 4120 -12 Hg 99% 27° 4.14sT 94°c 31°c 13.38v 12.5 . . . . '
# 277 4180 -09 Hg 99% 27° 4.71sT 94°c 31°c 13.38v 12.8 . . . . '
# 278 4180 -08 Hg 99% 27° 5.14sT 94°c 31°c 13.38v 13.0 . . . . '
# 279 4120 -02 Hg 99% 25° 4.62mS 94°c 31°c 13.38v 13.4 . . RPMwot . '
# 280 4120 +00 Hg 99% 25° 4.81mS 94°c 31°c 13.32v 13.6 . . RPMwot . '
# 281 4180 +00 Hg 99% 25° 4.81mS 94°c 31°c 13.18v 14.5 . . RPMwot . '
# 282 4320 +03psi 99% 25° 5.86mS 94°c 31°c 13.18v 13.8 . . RPMwot . '
# 283 4320 +03psi 99% 25° 5.90mS 94°c 31°c 13.25v 13.6 . . RPMwot . '
# 284 4320 +02psi 99% 25° 5.76mS 94°c 31°c 13.25v 13.7 . . RPMwot . '
# 285 4320 +02psi 99% 25° 5.67mS 94°c 31°c 13.25v 13.5 . . RPMwot . '
# 286 4380 +04psi 99% 25° 6.14mS 94°c 31°c 13.25v 13.5 . . RPMwot . '
# 287 4180 -20 Hg 34% 27° 2.57sT 94°c 31°c 13.38v 13.3 . . . . '
# 288 3620 -27 Hg 00% 10° 2.86sT 94°c 31°c 13.44v 14.7 . . IDLE . '
# 289 3250 -27 Hg 00% 10° 2.86sT 94°c 31°c 13.44v 14.7 . . IDLE . '
# 290 3000 -27 Hg 00% 10° 2.86sT 94°c 31°c 13.44v 14.7 . . IDLE . '
# 291 2950 -27 Hg 00% 10° 2.86sT 94°c 31°c 13.44v 14.7 . . IDLE . '
# 292 3000 -27 Hg 00% 10° 2.86sT 94°c 31°c 13.44v 14.7 . . IDLE . '
# 293 3060 -27 Hg 00% 10° 2.86sT 94°c 31°c 13.44v 14.7 . . IDLE . '
# 294 3000 -27 Hg 00% 10° 2.86sT 94°c 32°c 13.44v 14.7 . . IDLE . '
# 295 3000 -27 Hg 00% 10° 2.86sT 94°c 32°c 13.44v 14.7 . . IDLE . '
# 296 3000 -27 Hg 00% 10° 2.86sT 94°c 32°c 13.44v 14.7 . . IDLE . '
# 297 3000 -27 Hg 00% 10° 2.86sT 94°c 32°c 13.44v 14.7 . . IDLE . '
# 298 3000 -23 Hg 82% 27° 2.57sT 94°c 32°c 13.44v 14.7 . . . . '
# 299 2950 -16 Hg 99% 30° 4.05sT 94°c 32°c 13.44v 13.2 . . Pump2 M . '
# 300 2950 -14 Hg 99% 28° 3.71sT 94°c 32°c 13.44v 12.8 . . Pump2 M . '
# 301 2950 -14 Hg 99% 28° 3.62sT 94°c 32°c 13.44v 13.0 . . . . '
# 302 2950 -16 Hg 99% 28° 3.29sT 94°c 32°c 13.44v 13.2 . . . . '
# 303 2950 -15 Hg 99% 28° 3.33sT 94°c 32°c 13.44v 13.1 . . . . '
# 304 2950 -16 Hg 99% 28° 3.19sT 94°c 31°c 13.44v 13.4 . . . . '
# 305 2950 -16 Hg 99% 28° 3.14sT 94°c 31°c 13.44v 13.2 . . . . '
# 306 2950 -17 Hg 95% 28° 3.00sT 94°c 31°c 13.44v 13.2 . . RPMcrs . '
# 307 2950 -19 Hg 88% 28° 2.86sT 94°c 31°c 13.44v 13.0 . . RPMcrs . '
# 308 2880 -21 Hg 70% 27° 2.57sT 94°c 31°c 13.44v 12.8 . . . . '
# 309 2880 -21 Hg 69% 27° 2.57sT 94°c 31°c 13.44v 12.4 . . . . '
# 310 2880 -22 Hg 70% 27° 2.57sT 94°c 31°c 13.44v 12.3 . . . . '
# 311 2880 -22 Hg 70% 27° 2.57sT 94°c 31°c 13.44v 12.3 . . . . '
# 312 2880 -22 Hg 69% 27° 2.57sT 94°c 31°c 13.44v 12.3 . . . . '
# 313 2880 -22 Hg 69% 27° 2.57sT 94°c 31°c 13.44v 12.4 . . . . '
# 314 2880 -22 Hg 68% 27° 2.57sT 94°c 31°c 13.44v 12.5 . . . . '
# 315 2820 -21 Hg 69% 27° 2.57sT 94°c 31°c 13.44v 12.3 . . . . '
# 316 2820 -21 Hg 78% 27° 2.57sT 94°c 31°c 13.44v 12.3 . . . . '
# 317 2820 -19 Hg 99% 28° 2.71sT 94°c 31°c 13.44v 12.5 . . RPMcrs . '
# 318 2820 -15 Hg 99% 28° 3.48sT 94°c 31°c 13.44v 14.7 . . . . '
# 319 2820 -13 Hg 99% 28° 3.86sT 94°c 31°c 13.44v 14.7 . . . . '
# 320 2820 -14 Hg 99% 28° 3.62sT 94°c 31°c 13.44v 14.7 . . . . '
# 321 2820 -12 Hg 99% 28° 4.05sT 94°c 31°c 13.44v 14.4 . . . . '
# 322 2820 -10 Hg 99% 27° 4.43sT 94°c 31°c 13.44v 13.6 . . . . '
# 323 2750 -10 Hg 99% 27° 4.33sT 94°c 31°c 13.44v 13.6 . . . . '
# 324 2820 -10 Hg 99% 28° 4.43sT 94°c 31°c 13.44v 13.7 . . . . '
# 325 2820 -09 Hg 99% 27° 5.00sT 94°c 31°c 13.44v 13.7 . . . . '
# 326 2820 -10 Hg 99% 27° 4.57sT 94°c 31°c 13.44v 13.6 . . . . '
# 327 2820 -07 Hg 99% 27° 5.43sT 94°c 31°c 13.38v 13.4 . . . . '
# 328 2820 -05 Hg 99% 25° 6.05sT 94°c 31°c 13.38v 13.3 . . . . '
# 329 2820 -05 Hg 99% 25° 6.00sT 94°c 31°c 13.38v 13.3 . . . . '
# 330 2820 -05 Hg 99% 27° 6.05sT 94°c 31°c 13.38v 13.3 . . RPMwot . '
# 331 2820 -04 Hg 99% 25° 6.33sT 94°c 30°c 13.38v 13.2 . . RPMwot . '
# 332 2820 -05 Hg 99% 25° 5.86sT 94°c 30°c 13.38v 13.3 . . RPMwot . '
# 333 2820 -04 Hg 99% 25° 6.33sT 94°c 30°c 13.38v 13.3 . . RPMwot . '
# 334 2820 -04 Hg 99% 25° 6.33sT 94°c 30°c 13.38v 13.2 . . RPMwot . '
# 335 2820 -04 Hg 99% 25° 6.33sT 94°c 30°c 13.38v 13.1 . . . . '
# 336 2820 -09 Hg 99% 27° 4.86sT 94°c 30°c 13.38v 13.1 . . . . '
# 337 2820 -09 Hg 99% 27° 4.86sT 94°c 30°c 13.38v 13.2 . . . . '
# 338 2880 -09 Hg 99% 27° 4.86sT 94°c 30°c 13.44v 13.3 . . . . '
# 339 2820 -09 Hg 99% 27° 4.86sT 94°c 30°c 13.44v 13.5 . . . . '
# 340 2880 -10 Hg 99% 27° 4.33sT 94°c 30°c 13.44v 13.4 . . . . '
# 341 2820 -08 Hg 99% 27° 5.05sT 94°c 30°c 13.44v 13.5 . . . . '
# 342 2820 -09 Hg 99% 27° 4.86sT 94°c 30°c 13.44v 13.5 . . . . '
# 343 2820 -08 Hg 99% 27° 5.33sT 94°c 30°c 13.38v 13.4 . . . . '
# 344 2820 -08 Hg 99% 25° 5.29sT 94°c 30°c 13.38v 13.4 . . . . '
# 345 2880 -05 Hg 99% 25° 5.90sT 94°c 30°c 13.38v 13.3 . . . . '
# 346 2820 -05 Hg 99% 27° 5.90sT 94°c 30°c 13.38v 13.2 . . . . '
# 347 2820 -08 Hg 99% 27° 5.14sT 94°c 30°c 13.38v 13.2 . . . . '
# 348 2820 -08 Hg 99% 27° 5.29sT 94°c 30°c 13.38v 13.3 . . . . '
# 349 2880 -07 Hg 99% 27° 5.43sT 94°c 30°c 13.38v 13.3 . . . . '
# 350 2820 -08 Hg 99% 27° 5.33sT 94°c 30°c 13.38v 13.3 . . . . '
# 351 2880 -08 Hg 99% 27° 5.33sT 94°c 30°c 13.38v 13.3 . . . . '
# 352 2820 -08 Hg 99% 27° 5.33sT 94°c 30°c 13.38v 13.3 . . . . '
# 353 3180 -12 Hg 99% 28° 4.19sT 94°c 30°c 13.44v 13.3 . . . . '
# 354 3380 -25 Hg 17% 27° 2.57sT 94°c 30°c 13.44v 12.8 . . . . '
# 355 3120 -26 Hg 00% 10° 2.86sT 94°c 30°c 13.44v 14.7 . . IDLE . '
# 356 2880 -12 Hg 99% 30° 5.14sT 94°c 30°c 13.44v 14.7 . . Pump2 M . '
# 357 3320 -15 Hg 99% 28° 3.33sT 94°c 30°c 13.44v 12.5 . . Pump2 M . '
# 358 3880 -15 Hg 99% 28° 3.33sT 94°c 30°c 13.44v 12.8 . . . . '
# 359 3880 -15 Hg 99% 28° 3.33sT 94°c 30°c 13.44v 13.1 . . . . '
# 360 3880 -15 Hg 99% 28° 3.43sT 94°c 30°c 13.44v 13.3 . . . . '
# 361 3820 -13 Hg 99% 28° 4.00sT 94°c 30°c 13.44v 13.3 . . . . '
# 362 3880 -13 Hg 99% 28° 3.86sT 94°c 30°c 13.44v 13.4 . . . . '
# 363 3880 -13 Hg 99% 28° 3.90sT 94°c 30°c 13.44v 13.5 . . . . '
# 364 3820 -10 Hg 99% 27° 4.33sT 94°c 30°c 13.44v 13.6 . . . . '
# 365 3880 -13 Hg 99% 28° 3.86sT 94°c 30°c 13.38v 13.7 . . . . '
# 366 3880 -09 Hg 99% 27° 4.71sT 94°c 30°c 13.38v 13.7 . . . . '
# 367 3820 -13 Hg 99% 28° 3.86sT 94°c 30°c 13.38v 13.6 . . . . '
# 368 3880 -12 Hg 99% 28° 4.29sT 94°c 30°c 13.38v 13.6 . . . . '
# 369 3880 -09 Hg 99% 28° 4.76sT 94°c 30°c 13.38v 13.6 . . . . '
# 370 3820 -10 Hg 99% 28° 4.43sT 94°c 30°c 13.38v 13.6 . . . . '
# 371 3880 -12 Hg 99% 27° 4.05sT 94°c 30°c 13.38v 13.6 . . . . '
# 372 3820 -12 Hg 99% 27° 4.05sT 94°c 30°c 13.38v 13.5 . . . . '
# 373 3820 -08 Hg 99% 27° 5.05sT 94°c 30°c 13.38v 13.5 . . . . '
# 374 3880 -07 Hg 99% 27° 5.62sT 94°c 30°c 13.38v 13.5 . . . . '
# 375 3880 -04 Hg 99% 25° 6.43sT 94°c 30°c 13.38v 13.5 . . RPMwot . '
# 376 3820 -02 Hg 99% 27° 4.57mS 94°c 30°c 13.38v 13.5 . . RPMwot . '
# 377 3880 -03 Hg 99% 25° 4.52mS 94°c 30°c 13.38v 13.4 . . RPMwot . '
# 378 3880 +00 Hg 99% 25° 4.81mS 94°c 30°c 13.32v 13.3 . . RPMwot . '
# 379 3950 +00 Hg 99% 25° 4.81mS 94°c 30°c 13.32v 13.4 . . RPMwot . '
# 380 3880 -02 Hg 99% 25° 4.71mS 94°c 29°c 13.32v 13.4 . . RPMwot . '
# 381 3950 -09 Hg 99% 30° 6.05sT 94°c 30°c 13.38v 12.4 . . Pump2 M . '
# 382 4000 -10 Hg 99% 27° 4.33sT 94°c 30°c 13.38v 12.7 . . Pump2 M . '
# 383 3950 -10 Hg 99% 27° 4.48sT 94°c 30°c 13.38v 12.7 . . . . '
# 384 4000 -10 Hg 99% 27° 4.48sT 94°c 30°c 13.38v 12.9 . . . . '
# 385 4000 -08 Hg 99% 27° 5.05sT 94°c 30°c 13.38v 13.0 . . . . '
# 386 3950 -09 Hg 99% 27° 4.76sT 94°c 30°c 13.38v 13.1 . . . . '
# 387 3950 -12 Hg 99% 28° 4.29sT 94°c 30°c 13.38v 13.2 . . . . '
# 388 4000 -12 Hg 99% 28° 4.05sT 94°c 30°c 13.38v 13.3 . . . . '
# 389 3950 -12 Hg 99% 28° 4.14sT 94°c 30°c 13.38v 13.3 . . . . '
# 390 4000 -12 Hg 99% 28° 4.14sT 94°c 30°c 13.38v 13.3 . . . . '
# 391 3950 -12 Hg 99% 28° 4.29sT 94°c 30°c 13.38v 13.4 . . . . '
# 392 4000 -10 Hg 99% 28° 4.48sT 94°c 30°c 13.38v 13.4 . . . . '
# 393 4000 -10 Hg 99% 27° 4.43sT 94°c 30°c 13.44v 13.4 . . . . '
# 394 3950 -12 Hg 99% 28° 4.14sT 94°c 30°c 13.44v 13.4 . . . . '
# 395 4000 -12 Hg 99% 28° 4.29sT 94°c 30°c 13.44v 13.4 . . . . '
# 396 3950 -12 Hg 99% 28° 4.14sT 94°c 30°c 13.44v 13.5 . . . . '
# 397 4000 -12 Hg 99% 28° 4.19sT 94°c 30°c 13.44v 13.5 . . . . '
# 398 4000 -12 Hg 99% 28° 4.29sT 94°c 30°c 13.38v 13.5 . . . . '
# 399 3950 -10 Hg 99% 28° 4.33sT 94°c 30°c 13.38v 13.6 . . . . '
I'm going to log the way back to work and try to pay closer attention to exactly when it happens...
Old May 16, 2003 | 11:31 AM
No7Yet's Avatar
Whoa that was a huge post. Next time, just rename it to a .txt file or zip it up or something!
Next, what is it doing? I don't know what to look for! What are you doing when it happens? "80-160" is 1/6th of the log - we need more info than that.
Brandon
BR7 Racing
Old May 16, 2003 | 12:38 PM
Josepi's Avatar
Despise Enmity
I'm still getting a hesitation around 4-4500.
Going to change the plugs this weekend (now that I have it running steady and it shouldn't be flooding). Changing the...that one thing to 180 (had 2 pints for lunch...) helped out with the 3-3400 hesitation. Next up is fuel filter and fuel pump.
Questions I do have:
1. Does the map overall look "normal"?
2. It's hard for it to stay on crs it seems...I'm presuming that means that the ECU is detecting the current state of "cruise"...is it only supposed to appear as few times as is does?
3. From line 308-352, I'm supposed to be at one RPM. It *seemed* like it was holding steady at a single RPM. But as you can see, it bounces ~60RPM. Any suggestions as to a cause?
4. The "hesitation" occured between lines 80 and 118...does the status look correct?
Old May 16, 2003 | 12:51 PM
Josepi's Avatar
Despise Enmity
PS:
The hesitation doesn't always occur.
Old May 16, 2003 | 07:48 PM
SaabGuy's Avatar
try increasing the % manifold pressure change for pump2. Seems it was comming on a bit funny in the area which you meantioned.
Also looks like you might be running a bit rich in that area when you are not boosting. Bring that thing to a dyno.
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
NoMorePoison
11
Aug 18, 2015 11:18 AM
