Sponsored by: CARiD
Twin Turbo
Old May 16, 2003 | 07:28 AM
OtakuRX's Avatar
The Rotorheaded Geek
Question Twin Turbo
Ok, I am stripping a 13B-REW of all the emissions vacuum stuff, and I need to know how the vacuum works with the turbos. I know that they use vacuum to switch between each other, but can I use an aftermarket BOV & wastegate to run them or is there some vacuum system that does it that I would need to close off.
Old May 16, 2003 | 09:44 AM
Cosmo Donk's Avatar
Queer
Personally I would run the non-sequentially. I have that set-up on my Cosmo and it gets rid of a LOT of confusion. You will need to pull the flapper door out for the manifold and the y-pipe and then you can easily plumb them with any ol boost controller.
Skeese
65
Mar 28, 2017 03:30 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
