Sponsored by: CARiD
Rough Idle
Old May 15, 2003 | 08:59 PM
flavamon's Avatar
Newbie
Rough Idle
Idles rough but smooth at cruising speeds on a 1987 non-turbo 5-speed. Rebuilt primary fuel injectors, and checked fuel filter, also new plugs. I am no rotary mechanic, an independent shop did the work, but they cannot fix the rough idle. Any ideas on what I can try, or do you know of a good shop within a 200 mile radius of Charlston, SC?
Old May 16, 2003 | 09:38 AM
Cosmo Donk's Avatar
Queer
When car is idling take a spray can of carb cleaner or WD-40 and spray near the intake and vacuum lines. You are listening for a raise in the idle and if that happens you have a vacuum leak. There is most likely a leak in a gasket or line around the engine.
-E
Old May 22, 2003 | 06:26 PM
MRGSL-SE's Avatar
ROTOR THAT PUSSY BITCH
clean everything
h r p
kuuva86
Sep 28, 2015 05:42 AM
Jmolina0163
19
Sep 25, 2015 06:06 PM
firzen
Sep 15, 2015 12:04 PM
RotaryBobby
Sep 10, 2015 01:33 PM
