Exhaust ....Can I remove Cat
Old May 14, 2003 | 09:23 PM
Knightdulac's Avatar
83 RX7
Can I remove cat and replace with straight pipe or something ????
Is this good ..bad or other???
Thanks
Old May 14, 2003 | 09:33 PM
Sparky69's Avatar
Who are u?
good thing take it off..
Old May 14, 2003 | 10:21 PM
Pele's Avatar
Right near Malloy
Do ya gotta pass emissions? If not, ditch it.
Old May 14, 2003 | 10:38 PM
No don't have to pass anything around here was worried about performance ...is the blocking off of anything else needed or a problem???
Old May 14, 2003 | 10:45 PM
1984special's Avatar
So little time and money
Illinois don't have no emissions? Shucks. I was about to go to Urbana Champaign for college, but didn't get into their engineering program (top tier). I would've LOVED to zoom around in a smog-exempt rotary...
Happy polluting! I mean rotoring of course.
Old May 14, 2003 | 10:47 PM
1st to 3rd's Avatar
Option #1) http://www.rx7.com/cgi-local/1catalog.cgi?cat=4&part=2
Cheaper, but don't gain as much since the stock manifold is retained.
Option #2) http://www.mazdatrix.com/r-8.htm
Header and Pre-sliencer is the way to go IMO.
Old May 14, 2003 | 10:50 PM
Thank you ..
And in the South ...... sort of out of the way
Old May 15, 2003 | 11:28 AM
zaridar's Avatar
35r 13b first gen
Yeah go straight pipe
unless you are worried about noise you might want a presilencer rb has great ones!
Old May 15, 2003 | 11:42 AM
brianmcd's Avatar
I'd go with the full racing beat exhaust if you have the money. I have it on my 1983 GSL and it is awesome. It removes the cat, puts a presilencer in. Removing the cat will give you some horsepower, especially since it's probably a little clogged on a 20 year old car.
Old May 15, 2003 | 04:03 PM
Rx7carl's Avatar
Airflow is my life
With the stock exh manny and stuff, a straight pipe wont be that loud. www.testpipe.com like $30. But I'd suggest you gut the precats if they are not already hollow.
Old May 15, 2003 | 06:24 PM
zaridar's Avatar
35r 13b first gen
Or you could stick a pipe through your cat and weld it in thats what i did so if a cop pulls you over and takes a look its still there but actually its a straight piped exhaust!!!
Old May 15, 2003 | 07:40 PM
Rx7carl's Avatar
Airflow is my life
Ahhhhhhhhhhhh veddy veddy slick!
Skeese
65
Mar 28, 2017 03:30 PM
msilvia
28
Apr 14, 2016 12:58 PM
86glxNA
Aug 15, 2015 01:45 PM
