putting 13b plugs in my 12a Is it safe
Old May 13, 2003 | 11:45 PM
hi this is rotary addiction and yes i havent fixed my overheating probs but i pulled the plug and turnt it over no water yes!!!!! but i noticed the plugs were cheap pos plugs they were autolite 2526 all the same no leading or trailing just 2526 all four, now i have a fairly new been run for five minutes in a water swallowing 13b NGKs can i take the NGKs and put the 13b plugs in my 12a
o by the way its an 84 12a in a GS
thanks im replacing the thermostat first if that doesent do it ill pull radiator
THANK YOU ALL FOR VIEWING AND REPLYING TO MY POSTS
Rotary Addiction
Old May 13, 2003 | 11:54 PM
Hyper4mance2k's Avatar
The Shadetree Project
yes its safe. its worth nothing. 13b plugs are too shrouded and suck. I run stock NGK 12a plugs in my 13b. Its all about the bur8eq-13's baby!!
Old May 14, 2003 | 11:21 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
What are you talking about? The "stock" plugs for 13B and 12A are NGK BR8EQ14 with four side wires. How is that "shrouded" in comparison with the BUR plugs which fire down inside a cavity and cost an arm and a leg? The BEST performance is achieved with plugs that have a SINGLE side wire, but they don't last long enough for the average street driver. I'll get off my soapbox now...
Old May 14, 2003 | 01:22 PM
anthrax's Avatar
Heck Yes!
I thought they were the same plugs in the 12A and 13B OE. I just bought four new ones from the parts supplier, and when he asked me what motor I had I told him, then he said never mind they are the same plug.
Old May 14, 2003 | 02:13 PM
slag's Avatar
nope, they are most definitely not the same.
Old May 14, 2003 | 03:11 PM
Northern 7's Avatar
I use the shrouded platinum plug (for turbo's) and find they last a lot longer than the stock plug.
Old May 15, 2003 | 03:44 AM
karism's Avatar
Adolf Hitler Verfechter
i use normal single earth plugs (ngk b8es)its actually two stroke plugs.they work great,but dont last long.
Old May 16, 2003 | 01:25 AM
oops i ment br8eq-14 was the stock 12a plug, *******. it was a long day. i work 8 days a week and 9 hours a day so fawk off. The stock 13b plugs are bur7eq in the leading and bur9eq in the trailing. ******* And the 13b plugs cost the same as the 12a plugs at my local parts depot. sucks for you beioch
Old May 16, 2003 | 10:50 AM
Wankelguy's Avatar
Thank you so much for confirming your immaturity and ignorance with your pathetic name-calling and profanity.
alphawolff
Nov 17, 2015 05:57 PM
Josh83rx7
Sep 2, 2015 05:57 PM
Wolf_
Aug 11, 2015 04:23 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
