hmm, not the master cylinder...
Old May 13, 2003 | 08:15 PM
damian's Avatar
DDH Motorsports
Top Answer: 1
Question hmm, not the master cylinder...
so in an effort to fix my 'deep' pedal brake problem, I decided to replace my master cylinder...also based on many suggestions that it was bypassing, making the pedal spongy, travel way deep to brake, et.
..but thats not it, why? cuz I just replaced it with a new one, no change, even after being bleed twice.
now im wondering if it is the power brake push rod, needing adjustment to get the force back up at the top of the arch of pedal travel.
Anyone ever have to adjust this?
Any other ideas, ABS is bad, what...anyone ...Bueler?
Old May 14, 2003 | 12:50 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
wow, nobody?...nothing?
Old May 14, 2003 | 12:58 AM
skunks's Avatar
I'm a CF and poop smith
are you sure your bleeding it correctly? perhaps you got a leak some place, try putting some of that special uv light stuff in your car and using a black light to try to track down the problem.
Old May 14, 2003 | 01:39 AM
damian's Avatar
DDH Motorsports
Top Answer: 1
no leak, it holds fluid fine...here is a new theory i have, that is the PBV (proportioning bypass valve)... but im speculating
this valve makes it give more force to front/less to back...and I noticed my fronts dont look as worn as my back, and it should be opposite, especially after a few good tack events..... so i wonder if that is it?
Ohh, well, i have a master cylinder FS if anyone needs one :-)
Evan Kurtz
Sep 13, 2015 08:40 PM
