why the tranny is hard to put in gear????
Old May 11, 2003 | 02:24 PM
e20v02o's Avatar
me and my friend we just change the tranny oil in his 93 rx7 and we put in 75w-90 from mazda dealer... and somehow before is hard to put in gear when is cold....
but now after we change it and it still does it....
and the car has only 30000 miles... so is that the tranny problem, clutch problem or i need some different kind gear oil????
thank you for help
Old May 11, 2003 | 02:36 PM
Rotarded's Avatar
"Challenged" since 1993
You might try adjusting the cluch pedal. If that doesn't make a difference, bleed the clutch.
Mike
Old May 11, 2003 | 02:37 PM
Rx-7$4$me's Avatar
yeah I was gonna say bleed the clutch
Old May 11, 2003 | 03:30 PM
You have to make sure you have exact amount of fluid in there,if you overfill it it might be hard to shift.Also your pilot bearing might be going bad.....
Old May 13, 2003 | 04:02 PM
e20v02o's Avatar
well i'll try to bleed the clutch, thank you all for help.
Th0m4s
Feb 26, 2019 02:04 AM
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
