diff problems NEED HELP/A NEW DIFF?????
Old May 9, 2003 | 09:50 PM
Unhappy diff problems NEED HELP/A NEW DIFF?????
I was at the track tonight (first time this season--after getting my tranny put back together)--after a 3200 rpm launch, and a low 13 sec pass I lined up for my second run. A 4500 rpm launch and about a 4 foot roll later; I have blown my LSD. WHY MAZDA WHY?
I was hoping some of my fellow forum members would know where I could find some DIFF parts (or a whole LSD)
I will be disassembling the diff tomorrow to see if the thing is salvageable....but in the meantime I would like to price out a replacement. Any help or point in the right direction is greatly appreicated.
Also---does anyone know how many HP this thing should handle??? I have heard it can take 400+
if this is true--than why I am breaking diffs? Thanks for your help.
Old May 9, 2003 | 11:21 PM
vosko's Avatar
Just Call Me Terminator!
what kind of tires are you using. do you know how you broke it ? my suggestion would be get a whole used rear end, then put in a brand new T2 clutch type LSD. that is what i have and it has taken my abuse without worry
Old May 10, 2003 | 09:50 AM
Astro's Avatar
how about a kaaz
Old May 10, 2003 | 11:33 AM
vosko's Avatar
kaaz is better but it seems to be the exact same thing as a TII clutch type,i think you are paying for the name
Old May 10, 2003 | 08:36 PM
T88Rx7's Avatar
wait or you the dude with the red Fd thats was running with the 18 in rims
Old May 11, 2003 | 10:02 AM
no I have a white fd w/ stock wheels , I was only able to drain the diff and I can see parts in the oil and in the bottomof the diff
Old May 11, 2003 | 01:25 PM
spoolin93r1's Avatar
i just ordered my kaaz a couple days ago, and hopefully install it next this next weekend. if you need somethin to get ya goin again, i could sell ya my stock diff
Old May 11, 2003 | 07:20 PM
to_slow's Avatar
Dam that sucks . I did the same thing at Rx7 revolution on the last run of the day . I went with a kazz , it feels strong and drives good . My suggestion is if you pull out the diff might as well upgrade . If you tight on $$$ get the t2 diff if not kazz is the way to go .
Here are some good Facts about the kazz.
enjoy, kind a long tho.
KAAZ LSD CLutch type (KAAZ) vs Torsen (brand X)
First off: we get the same questions from people when they ask us why we don't sell Torsen type LSD's. First of all we don't like the people at that 'other LSD company' they're dicks. Secondly in our opinion they sell an inferior product that is way overpriced. The dudes at KAAZ are really cool, and the KAAZ LSD is one of the baddest LSD's out there and we're going to list the reasons why we only sell KAAZ.
Why, should you buy a KAAZ LSD?
Some have heard complaints about the KAAZ LSD being too noisy. First of all, they are only noisy in slow speed corners, like parking lot situations. How much time do you spend in a parking lot with your performance car? If you do a lot of parking lot driving, and hang out in parking lots, chances are you are a ricer, go home and read import tuner. If you're complaining about noise you should not be modifying your car. You should also consider no longer being a man, please hand in your genitals at the door.
Here's why Torsen LSD's suck. For you road racer types, as soon as you get one wheel off the ground the Torsen becomes an open differential, in order for it to work both wheels must have complete contact with the ground. When your hanging 1.1g corners and a wheel lifts under power you instantly have no power. That sucks real bad. The KAAZ clutch type LSD is not like that. The KAAZ LSD will remain engaged when a wheel lift under cornering.
Rally drivers and road race types alike prefer these Clutch type LSD's because they are more predictable, they will always do the same thing over and over again. Repeatability is very important if you want to achieve consistency. Manufacturers, and race teams alike (Mazdaspeed, Nismo, etc) use the clutch type design. It is the one that works. When people say words like Mazdaspeed, RE Amemiya and Nismo you should all bow in reverence, the rest of the world does.
Another problem associated with Torsen type differentials is that by design they try and force the internal gears against the housing in order to achieve the breaking force which will lock the LSD. The same features that make the Torsen quiet make it weak. When a Torsen breaks, it breaks its own housing and sends expensive little bits everywhere, usually breaking the transmission/rear end gear/housings with it. We do not like weakness, refer to second paragraph regarding handing in your *********.
Now for you Drag racer types, this is where you want the direct engagement of a clutch type differential like a KAAZ. The KAAZ 1.5 way and 2 way diffs, have a cam lock type of engagement. When power is applied, it immediately engages the clutch packs, which in turn locks the wheels. What does this mean to you? Reaction time, lips, that's what. It reacts right away, and it has direct engagement. Important when trying to rip off good good times. The Torsen type must have slippage in order for it to engage both wheels, this costs you time.
KAAZ LSD's can be rebuilt whereas Torsen types require little if no servicing. True but lets look into this further shall we? Usually a clutch type LSD will not require servicing until about 100,000 miles into its life, and the parts are all available separately. We say, so what? I can have a better LSD, which in ten years I may have to service, or I can have the chance of having my tranny reduced to a pile of rubble. In ten years I won't own this pile of scrap, I may be dead, or I'll be driving a porsche, better yet, I'll be chauffeured around town in my limousine surrounded by my harem of Truly 18 poster girls.
Now that you have the facts you can be the judge, oh by the way KAAZ LSD's are usually half the price of a Torsen type. That should seal the deal right there.
Old May 11, 2003 | 10:22 PM
vosko's Avatar
to slow is correct. kaaz are very good and rebuildable in the US
Old May 12, 2003 | 04:42 PM
Who is selling the kaaz Lsd and what is the price range? I am not looking for the lowest price to get my car up and driving, I want the best. I don't like replacing parts again, because I went with the cheaper part.
ZacMan
Sep 19, 2015 09:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
