Efini Y-pipe
Old Aug 31, 2001 | 04:05 AM
Tobal's Avatar
Efini Y-pipe
Hey, i just bought and installed a efini Y-pipe today. The thing is that i dont' see much of a difference in the OEM part and the efini Y-pipe. What should i expect with this upgrade?
Old Aug 31, 2001 | 05:01 AM
RX7 RAGE's Avatar
Bann3d. I got OWNED!!!
Top Answer: 1
increased reliability
Old Aug 31, 2001 | 02:41 PM
rx7tturbo's Avatar
Re: Efini Y-pipe
Don't expect to get an increase in power because you won't.
I will buy it from you if you don't want it anymore..
Old Aug 31, 2001 | 05:32 PM
Malachi151's Avatar
from Children of the Corn
It is claimed to be good for 10 HP. I doubt it does anything for relaibility though, unless your talking about the aluminium crossover pipe that comes with it.
Old Aug 31, 2001 | 09:12 PM
bbeavers's Avatar
Question Y-pipe
Tobal, Was it easy to install? do youn have to remove alot of stuff to get it in there?
Old Aug 31, 2001 | 09:53 PM
jr's Avatar
jr
Actually the rubber coupler that connects the OEM metal y pipe to the plastic crossover tube is a known problem. It tends to tear and/or pop off.
I think it's a good mod, supposedly has better flow due to relocating the BOV connector out of the air flow. MazdaComp claims 10-15 HP, I guess that could be accurate. But I like it for the reliability factor, and the fact that it can be polished.
Old Sep 1, 2001 | 01:18 AM
Tobal's Avatar
Well i hope i installed it correctly... seemed like a easy job at first and then i had to remove all these parts connected... i think its kind of a bitch to do. But after this you kinda have a idea of how your car is. But heres one big question that pops up in the install.. the inlet facing towards firewall with connects to the pipe w/ the actuator just plugs straight in right? Cuz it didnt' really stay all that tight but i guess after screwing everything it it stays in place. thats the only part i hesitate about. Please let me know this is how it suppose to be.
Old Sep 1, 2001 | 01:30 AM
Lunar7's Avatar
The y-pipe should fit in tightly.
Did you install a new oring?
It's part number N3A1-13-162.
This o-ring seals the y-pipe to the second turbo/actuator pipe.
Bauer778
Nov 4, 2015 04:42 PM
