idle/rev problem
Old May 8, 2003 | 10:13 AM
idle/rev problem
first of all, i just did a swap, and im 90% done, i have to put a drive shaft in, i kept my auto harness, and used a manual ecu of course, and did the needed wiring adjustments to get the car started,
my problem is, a rough idle, and when i rev the car, and gets to about 3000 rpm's, it shakes bad, and sputters, and acts like it wants to cut out, and actually does, like its not gettting enough air, or gas, or spark,
im gettinga code 33 (air bypass) and a code 39 (relief 2), i have no idea what these things do together, please help!
thanks
Old May 8, 2003 | 01:10 PM
bump
Old May 8, 2003 | 01:59 PM
tomaszjc7's Avatar
Did u try messing with the idel screw right under the intake elbow??
Old May 8, 2003 | 04:50 PM
i have not messed with the idle screw, i dont see how that would be my prob., but i will try anyway, thanks.
what is the 'rats nest'? and i talked to cover8 on how to wire it up to get it to start using the automatic harness with the manual ecu, and i figure he knows what hes talking about, thanks though, anymore ideas?
what about sparks plugs? it sat for 4 weeks without being cranked, would that be a cause?
thanks,
paul
Old May 8, 2003 | 04:56 PM
cover8's Avatar
30, 33 and 39 codes deal with your ACV...it is the large pollution control device located on the inside of the LIM (Lower Intake Manifold). This ACV device has three connections to the engine harness. To access you must remove the UIM and it is right above your injectors. To get this code one of those three wires/solenoids is disconnected or faulty.
Take an ohm meter and measure resistance on the acv solenoids. The correct resistanc will be in the manual...do not know off hand the values. This could effect your idle. Make sure when you re-install the ACV, that you use a new gasket and make sure you have proper seal.
Old May 8, 2003 | 05:23 PM
thanks cover8, its just strange to me that this could be the ACV, bc, it worked just fine before the swap, and now, it want even rev past 4000 rpms, but i will look into it, i will recheck my fuses, can u think of anything else that i might have done or didnt do, during the swap that could be causing this? thanks
Old May 8, 2003 | 08:04 PM
bizzump!
Old May 8, 2003 | 09:45 PM
coop's Avatar
Did you plug the map sensor back in? That can cause some messed up results...
Old May 8, 2003 | 11:29 PM
never unplugged it, but thanks, u are right, i have had that happen before, anybody else?
WyomingTII
Sep 28, 2015 10:32 AM
lnlreaper
Sep 27, 2015 09:59 AM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
