Bolts instead of Studs?
Old May 8, 2003 | 09:51 AM
ejmack1's Avatar
Lawn Ornament
Can I use bolts instead of studs when bolting the turbo's back on?
Old May 8, 2003 | 09:54 AM
DamonB's Avatar
I have a couple in mine since swapping motors, no problems.
I had about 4 turbo studs twist and break when I was tearing the motor down. I painstakingly drilled them out and retapped the holes in the exhaust manifold. I could not locate the proper studs that afternoon so I used garde 8 bolts in a few places. Should be just fine.
Old May 8, 2003 | 10:13 AM
cover8's Avatar
Make sure you use anti-seize on all of the bolts, sutds and nuts....and use a torque wrench.
Old May 8, 2003 | 10:28 AM
ejmack1's Avatar
Lawn Ornament
gotcha, is that the reason they used studs was because they would seize up? And a stud kind of gives you a second chance if the nut is stuck on...
toplessFC3Sman
Mar 20, 2018 01:54 PM
crackerjack
Canadian Forum
Oct 27, 2015 05:35 PM
