To Those Run Sequentially
Old May 6, 2003 | 10:15 PM
TwinTriangles's Avatar
What's an RX-7 ?
Im just curious what kind of transitions do you guys set when running sequentially like a 2lb transition from pri. to sec. such as 10psi to 12psi or 10psi to 13psi secondary...
And if anyone knows the stock settings for pri. & sec. boost that would be helpful also.
Thanks all.
JDub
Old May 6, 2003 | 10:20 PM
Resource's Avatar
Re: To Those Run Sequentially
Thanks all.
JDub
2 Psi is the norm if your system is working correctly.
Old May 6, 2003 | 10:27 PM
What's an RX-7 ?
2psi is stock transition, damn, when I was running the stock ecu it just seemed like such a pull diff upon transition, I might set my PFC for like 11pri. 15sec. and see what it feels like...
JDub
Queppa
Nov 18, 2024 03:47 AM
streetlegal?
Mar 17, 2022 02:46 PM
C. Ludwig
Jan 30, 2019 06:31 AM
The Shaolin
Sep 14, 2015 07:50 PM
