Got another one for the group
Old May 5, 2003 | 11:11 PM
tookwik's Avatar
VIP - Very Irish Person
Too bad this ones not mine, but my best friend picked this one up today. Other than repainting the headlight covers, this thing is sweet. street port (3mm seals), apexi fmic, koyo rad., supra pump, 99 spec turbos, Work Equip 3 piece rims. 265 in the rear. You name it, its got it.
Old May 5, 2003 | 11:14 PM
tookwik's Avatar
Old May 5, 2003 | 11:18 PM
tookwik's Avatar
My 7 in the rear
Old May 5, 2003 | 11:22 PM
tookwik's Avatar
wheel
Old May 6, 2003 | 07:17 AM
DaedelGT's Avatar
Uber Newb.
Didn't realize you could put the 99 front spoiler on a US spec front bumper. Cool.
Old May 6, 2003 | 11:17 AM
jpandes's Avatar
What the deal with those "braces" on the 99 front spoiler? Do we actually need these to support the Lip "at speed"? I mean, I have no way of knowing if mine bends up while "at speed".
And if we do need 'em, where can I get them?
Old May 6, 2003 | 12:13 PM
tookwik's Avatar
The braces are there for major support and adjustability. Have you ever just pushed a little on the '99 spec spoiler? It will bend just as far as you want to push, with very little resistance. I dont know how you mounted your '99 spec spoiler, but the "braces" work damn good and I dont think they look too bad either. I have some on my 7 too. You can even turn the turnbuckle and raise the lip for speed bumps and lower it for looks. The only problem I had was it pulled on the bumper too hard so I put a backing plate where it mounted tp spread the load.
All I did was go to home depot and bought (2) 5.5" turnbuckles with O loops on the end, I then bought 4 threaded O loop hooks, attached the O loops together using a 2 clamps to pry them apart and to put back to the normal position. Once each O loop hook is attached to both ends of the 2 turnbuckles, I screwed the O loop hooks into the lip and the bumper and then threaded them back into the turnbuckle. Pretty easy actually.
Old May 6, 2003 | 01:25 PM
curlybillbrosie's Avatar
why did he get new headlight covers?
Old May 6, 2003 | 01:32 PM
apneablue's Avatar
Team Home Depot at it again! Sweet ride dide...even if it's yur buds.
Old May 6, 2003 | 01:51 PM
Cihuuy's Avatar
i see two fd's one black and one montego blue... does your fren own them both??
IMHO, the braces looks cheap... just my .02
Old May 6, 2003 | 01:54 PM
tookwik's Avatar
No, the cars in the garage are mine, his is the mb one. I guess you actually have to see the brace in person. It does look a hell of a lot better on black cars then it does the mb's. He plans on painting his black.
Old May 6, 2003 | 01:55 PM
Cetchup's Avatar
The Cursed FD
Anyone the price on the Work wheels? Those are nice man!
Old May 6, 2003 | 01:57 PM
tookwik's Avatar
the headlight covers where hard to explain. The guy he bought if from said he was cruising one night around 120 mph, hit the stupid bumps usually before bridges and just heard a thunk. Turns out, the old headlight covers flew off.
Old May 6, 2003 | 02:01 PM
tookwik's Avatar
The Work wheels where bought used for 2000 including Pirelli something tires. The wheels are in not that great of condition close up.
Old May 6, 2003 | 02:06 PM
Cihuuy's Avatar
i would like to see your car instead... what wheels are you using? looks bling bling...
Old May 6, 2003 | 02:20 PM
jpandes's Avatar
I don't like the O loops that allow "play". I am going to look for a "cleaner" way to fasten them to the Lip. Good Idea, though.
Old May 6, 2003 | 03:00 PM
tookwik's Avatar
I agree, when you figure it out, post it up of where you got it. The one on the mb 7 was a kit of some kind. like $60
Old May 6, 2003 | 03:25 PM
DaedelGT's Avatar
Uber Newb.
Is the lip spoiler hollow? Even if it is, if you think it's strong enough, you could always drill all the way through and attach it with a low profile nut with that special thread lock nut thing on top of it.
Old May 6, 2003 | 03:30 PM
GeeHee13B's Avatar
Back at it...
****, a hoTT third gen 7, and a range rover. any openings where u work? need a son? damn. very nice. im very jealous
Old May 6, 2003 | 03:55 PM
tookwik's Avatar
The lip is not hollow, just formed plastic. Could you explain more about the low profile nut and special thread lock nut thing?
Old May 6, 2003 | 03:57 PM
tookwik's Avatar
Dont be man, the Rover is more problems than my 7.
Old May 6, 2003 | 04:16 PM
jpandes's Avatar
I was thinking the same thing. Just get a long bolt that will screw into the turn buckle instead of the O rings. You should be able to tighten it just by turning the turnbuckle.
Old May 6, 2003 | 04:18 PM
tookwik's Avatar
you would have to have a reverse thread bolt as well for it to work
Old May 6, 2003 | 04:34 PM
jpandes's Avatar
I think the turnbuckles are threaded that way. Left on one end and right on the opposite end.
Old May 6, 2003 | 05:39 PM
DaedelGT's Avatar
Uber Newb.
The thread locking nut I tried to name looks like a washer and spring put together. The more you tighten down the nut, the less they will move via friction.
