Which intercooler for 350 whp?
Old May 5, 2003 | 08:39 PM
rxnana's Avatar
Hi, I'm looking for an intercooler for my rx7. I'm planning on building the car to around 300-350 whp (w/ RZ turbo). Which intercooler should do the best job. I'm pretty sure I want a SMIC. My ideal will be minimum presure drop, quick response, and minimum engine bay temperature. Please give me some input, and explain why you suggest the intercooler. Thanks.
Old May 5, 2003 | 09:38 PM
half past twelve's Avatar
M2 Med, because everyone uses it.
Old May 5, 2003 | 09:40 PM
DeNguyen's Avatar
i have the greddy FMIC, put down a bit over 330rwhp with 14 lbs of boost. (110k on motor and turbos)
I havent had any trouble with heat issues or pressure drop.
Old May 5, 2003 | 10:22 PM
Street King's Avatar
*** Bless Texas!
2 or 3 row?
Old May 5, 2003 | 10:41 PM
zooq's Avatar
Greddy SMIC, it fits great and should be good up to 400-450whp
Old May 5, 2003 | 10:48 PM
Scrub's Avatar
bow leggin'
Just about any aftermarket intercooler will do the trick, as long as you don't go over 15 PSI. Then you will get more into the specific intercoolers.
Old May 5, 2003 | 11:34 PM
RX7SpiritR's Avatar
The Spirit of FLUFF!
the apexi FMIC is a nice unit and is designed for either single turbo or stock setup! It's sold with piping for stock turbos which is nice, throw that and the efini y-pipe and your good to go!
Old May 5, 2003 | 11:58 PM
artguy's Avatar
WTB** Very Low Miles 94-95
where is mahjic ?
He knows the answer to this question.
hehehe
j
Old May 6, 2003 | 01:16 AM
DeNguyen's Avatar
Originally posted by Street King
2 or 3 row?
2-row
Old May 6, 2003 | 07:03 AM
matty's Avatar
fmic is overkill for stock twins...get the m2 med..perfect setup for 350rwhp street driven FD....i am alittle biased though.
Old May 6, 2003 | 10:15 AM
DeNguyen's Avatar
how is it overkill?
Old May 6, 2003 | 11:30 AM
dubulup's Avatar
development
PFS SMIC is nice, get the efini Y...
Old May 6, 2003 | 11:40 AM
matty's Avatar
how is it overkill?
twins dont generate that much heat or that much psi, blocks rad, more lag...etc..
the trade off isnt great enough for me atleast.
Old May 6, 2003 | 11:44 AM
itrdanny2001's Avatar
get the Greddy 3 row!! Overkill!! You'll need to run over 15psi with this one though, correct me if i'm wrong.
and doesn't the M2 have fitting issues when you put in an aftermarket radiator? or is that just the bigger M2?
Old May 6, 2003 | 12:11 PM
artguy's Avatar
no..it doesnt...i have the mazda comp radiator and the m2 large. the m2 large is my favorite IC...its great.
you want something with the LEAST amount of pressure drop possible. the stock twins are already working overtime and if you get a good ic like the m2 then they do not have to work as hard to put boost through the system. the stock ic..if you want to run fifteen lbs...actually pushes over seventeen lbs just to get fifteen to show up because the stock ic is a POS. the fmic has pressure drop issues as well from what i understand. the m2 units have almost NO pressure drop at all and are thus the best choice among the setups.
since the m2 units are impossible to get..rotary reliability and racing has manufactured some for their shop. you should be able to get one from them if you want. I believe they are a couple hundred less than the m2 but are very similar in design and fitment.
you can reach ROTARY at 7148398018 ask for louis or nick.
j
Old May 6, 2003 | 12:55 PM
SPLzero's Avatar
wangan
does anyone knows the sizes of the cores on the SMIC's?
thanks
Josh
Old May 6, 2003 | 01:08 PM
Meatball529's Avatar
good choices
M2 med/large
Old May 6, 2003 | 01:38 PM
artguy's Avatar
www.scuderiaciriani.com has all the info...dig around and find the intercooler section.
j
Old May 6, 2003 | 03:46 PM
redrotorR1's Avatar
LS6 Convert
twins dont generate that much heat ...
Since when?!?!?!?!?!!!!!! The twins run HOT ....
IC-wise, I think the M2 and Greddy units offer the best performance of what's out there.
Old May 6, 2003 | 03:49 PM
matty's Avatar
well comparatively speaking....to a t78 at 25psi
Old May 6, 2003 | 08:23 PM
JimmyJimboJet's Avatar
boost deprived
i think it depends what you want to do with the car.
a lot of dragstrip runs? the general rule of thumb is go with a front mount
track? the general rule of thumb is a stock-mount, so you won't have to worry about overheating from blocking the radiator.
Old May 6, 2003 | 09:22 PM
turbojeff's Avatar
Do it right, do it once
The PFS in really nice because it fits well with the Efini pipe. I'd venture a statement it is the best fitting aftermarket IC for the FD.
The M2 med IC has a bigger core than the PFS, I like it alot too, but the fit could be better.
FMICs have fit issues IMHO, cutting up the front, etc isn't my idea of modding my sweet FD.
Old May 6, 2003 | 10:05 PM
DaedelGT's Avatar
Uber Newb.
What is the difference between the M2 medium and large ICs? I notice that they are the same cost, and people often recommend them at the same time.
Old May 7, 2003 | 12:42 AM
BenzaLee's Avatar
Got the m2 large with my rx6, love it.
Old May 7, 2003 | 02:08 AM
JspecFD's Avatar
The M2 large is essentially just a stretched medium IC core. Essentially, the large forces you to either relocate or miniaturize your battery and then takes up the space the battery previously occupied. So you get a bigger intercooler at the expense of more effort whereas the M2 med just fits right in with the stock battery(and most aftermarket intakes).
I'll second the opinion on the M2 as I've got the medium and the fitment is fine. I think Jason has them in stock in the RX7 Store or should be able to get them.
