where to buy metal vacuum t's
Old May 5, 2003 | 04:30 PM
turbogarrett's Avatar
0 lbs of boost
Question where to buy metal vacuum t's
i've called many auto parts stores with no luck. where did you find yours??
Old May 5, 2003 | 04:37 PM
LAracer's Avatar
I use plastic ones. Autozone, Ace Hardware, etc. No melting yet (did have one crack though), but I only use them for temporary debugging.
Old May 5, 2003 | 04:39 PM
DK's Avatar
DK
40k worth of fail
I use brass ones for plastic plumbing lines that I got at Lowe's.
Old May 5, 2003 | 04:45 PM
xstacy7's Avatar
I love when things work
home depot in plumbing section
Old May 7, 2003 | 08:08 PM
duboisr's Avatar
Garfinkle makes them from steel brake line stock. That way he can get 6 mm with 4mm t or 8mm with 4mm or 6mm t or what ever is needed . He can make vacuum line harness to fit the car so only short hoses are needed. That custom work is only done if the car is there. He did one for rotorbrain this week.The joints are fishtailed and brazed together .
Old May 8, 2003 | 10:51 AM
bros0000's Avatar
You could probably use an aquarium air line T, found at any pet store.
astrum
24
Nov 15, 2017 08:44 AM
Microtech
30
Apr 23, 2016 06:37 PM
pzr2
Aug 15, 2015 08:29 PM
