Microtech Wanna use your full-range TPS?
Old May 5, 2003 | 09:46 AM
No7Yet's Avatar
Keeping in mind that the full-range TPS isn't used for accelerator pump duties unless you're running in TPS load mode in vacuum, some people (myself included) wish to use the stock full-range TPS for datalogging and the like.
The Microtech diagram for the 13BT instructs you to use the narrow-range sensor in both S4 and S5 applications.
In order to use the full-range, use the following colors:
stock sensor - use - MT harness
Blue - ground - Brown
Pink - +5 VDC (Vref) - Blue
Yellow - signal - Grey
Buena suerte!
Brandon
BR7 Racing
LongDuck
Oct 7, 2015 08:12 PM
Einheri
Oct 7, 2015 12:23 PM
