Longer Lug Nuts?
Old Aug 30, 2001 | 12:40 AM
Longer Lug Nuts?
anywhere i can find longer lug nuts so i can fit my wheel spacers behind the stock turbo2 rims?
Mike
Old Aug 30, 2001 | 10:14 AM
CarmonColvin's Avatar
Longer Wheel Studs?
Don't you mean longer wheel studs?...
SpeedSource Inc carries them for FC's.
I think I paid nearly $5.00 each for them so be prepared to blow $200.00 for a full set.
I had to have them because some aftermarket racing wheels I purchased had a thicker face than stock. There is a safety standard (a tire/wheel shop told me this) that you must have at least 6 full turns on a lug nut for it to be safe. With out the longer studs I was only getting 2 or 3 turns, now there is 2+" of studs sticking out from the opened ended nuts.
The fronts were an easy install (once you get the old ones out of the hub). The rears were a complete pain. Because of the disign of the rear hubs you have to pull the actual hub part away from the carrier assembly to get the longer studs in there. And in turn you are most likely going to destroy your rear wheel bearings.. Beware the rears will not be an easy job. After destroying both wheel bearings and having my local dealership tell me the would only sell me a new hub for (? $200+ each?) I shipped both of my rear hubs to SpeedSource and for what I remember was under $100 in labor (+ parts from MazdaComp). They installed the longer studs, replaced the bearings and installed the rear toe elimator bushings.
SpeedSource can be found at www.speedsourceinc.com
Old Aug 30, 2001 | 10:32 AM
Sebring7's Avatar
damn! $200?!
Old Aug 30, 2001 | 12:47 PM
DOH!
Old Aug 30, 2001 | 01:45 PM
JerryLH3's Avatar
Rabbit hole specialist
Wouldn't $5 per stud x 20 studs (5 per wheel, 4 wheels) = $100
That's only half as much.
Old Aug 30, 2001 | 08:43 PM
My "Fuzzy Math".. oops
Yea.. I really was not clear in my previous post. I do know that $5 x 20 is $100 but at the time I was also thinking about the extra ~$100 I paid for the parts and labor for the work I had done on the rear hubs..
Old Aug 31, 2001 | 09:55 PM
JerryLH3's Avatar
Ah, now it makes sense. I knew most people on this forum knew basic math. So he just needs to somehow avoid tearing up the rear hubs.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
SpaceCadet_Alt3
Oct 1, 2015 11:35 PM
